Old 02-28-2022, 04:10 PM   #1
austintampa
Drives: honda element
Where are the forced induction dynos? Where are the stock block HP estimates?
Just curious when we can expect to see this information?
The bottom end internals are different on this generation - just surprised we havent seen more information about the stock block limits - and FI gains.
Am I just missing this conversation?
austintampa is offline   Reply With Quote
Old 02-28-2022, 04:23 PM   #2
Q8D
Drives: N/A
You're missing the glaring fact that 2022+ FA24 ECUs haven't been cracked yet.
No tuning = No boost
Q8D is offline   Reply With Quote
Old 02-28-2022, 05:29 PM   #3
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Yes, I am waiting for the first tunes to come out with the catless headers from the first gen. I assume it will be some significant amount of time after that before FI stuff starts happening. I mean, given the change in size of the engine, is it likely that Gen 1 FI solutions are going to work with little/no modification on Gen 2?
Heck, I was pretty surprised to find out you could swap the headers.
CincyJohn is offline   Reply With Quote
Old 03-01-2022, 12:57 AM   #4
PulsarBeeerz
Drives: JRSC BRZ SOLD
HKS is running a piggyback of some sort with their turbo kit in development, and is a littler over 300hp to the wheels.
PulsarBeeerz is offline   Reply With Quote
Old 03-03-2022, 07:16 PM   #5
Pete
Pete's Avatar
Drives: 22 BRZ
I was curious if we were going to have to start using piggybacks on this gen with the new ECU. When the information coming from Ecutek was not very encouraging I thought that was a strong indication towards yes.
I wonder how much that's going to affect the cost of tuning when you have to buy additional hardware + installation? Either way still going to get some parts + a tune when I can do so.
Or am I just jumping the gun and you think EcuTek will get it cracked eventually?
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 03-04-2022, 02:32 AM   #6
Brz-123
Ecutek is HQd in the UK. UK has not even got a launch date and price yet for gen 2 while Gen 1 was launched simultaneously globally. So work on it has not even started to predict how hard / easy it will be. They will crack it, am sure when they get onto it. No one has shared this gold dust of information, so pin the post
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 03-07-2022, 02:43 AM   #7
DriveDriftDogfight86
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
The FA24 is the same physical size as the FA20. That's why the headers still fit. The displacement is only larger because they increased the bore.
DriveDriftDogfight86 is offline   Reply With Quote
Old 03-07-2022, 09:55 AM   #8
Q8D
Drives: N/A
I'd guess the modifications that might be required are more likely due to the changes in body style than the engine itself. I'm taking a wild guess here but some of the differences might affect mounting points for the intercooler, fan shroud clearance, intake piping clearance around the radiator support, also throttle body location might be different since the intake manifold iirc is different. I could be wrong and all of this has remained unchanged
Old 03-09-2022, 06:14 AM   #9
Rxgolf
Drives: 2022 GR
To be transparent, I have not owned anything I wanted to ring more power out of in a long time. For those that have been in the weeds with this recently, what should expectations be?
I would love to hear some predictions as to what gains might be for folks looking for more out of their daily driver.
Will you be going with:
1.Full exhaust from headers out?
2.Turbo
3.Supercharger
4.ECU only
Just considering ways to get a bump without adding much weight and not losing dependability. What direction will you take?
Rxgolf is offline   Reply With Quote
Old 03-09-2022, 06:28 AM   #10
CincyJohn
2.Turbo
3.Supercharger
4.ECU only
I intend to do it exactly what I (and a lot of people) did on Gen1 - catless header + tune, preferably e85. On Gen1 those 3 things - header, tune, e85 - got you about a 15 percent gain, with a much better torque curve, in hp/torque at a cost of less than $1500 (the OFT tune was $500 and my JDL ceramic coated headers were $750 new). The reliability for this setup was not much different than stock.
I will reuse the headers on Gen2- just will be waiting for a tuning solution - which probably will be ECUTek first and will be more expensive than OFT - probably $1500, although admittedly it will be a more custom tune. Not sure OFT (or anyone else) will offer a tuning solution and don’t know when that will be.
Old 03-09-2022, 10:28 AM   #11
alphasaur
friendly
Drives: 17' 86
2.Turbo
3.Supercharger
4.ECU only
If the gr86 picks up as much as the first gen with a header, tune, and better fuel you will likely be looking at 230-240whp.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 03-13-2022, 10:21 AM   #12
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
So an increase 20-30 whp?
Didnt the first gens get more than this with headers/e85/tune? I see delicious tuning say that with the ace header and e85 they could get 40-45 hp...
Lies?
Blighty is offline   Reply With Quote
Old 03-13-2022, 11:57 AM   #13
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Lies?
They never advertised 45hp peak gains, they don't even claim that for the max under the curve gain. 15-30HP peak increase is what you'll see on the dyno numbers
Originally Posted by delicioustuning.com
Peak Horsepower Increase: +16-30 wheel horsepower
Peak Torque Increase: +16-25 wheel torque
Maximum Horsepower Gains: +18-35 wheel horsepower @ 7200 RPM
Maximum Torque Gains: +16-25 wheel torque @ 4200 RPM
PowerBand Expanded: +500 RPM's (by nearly eliminating the dip)
https://www.delicioustuning.com/Stag...SAAEgIWl_D_BwE
Old 03-15-2022, 04:23 PM   #14
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Since header, tune, and "better fuel" (E85) was mentioned, I believe @Blighty was referring to this link, which does advertise such gain. The link you provided is specific to headers and tune only.
https://www.delicioustuning.com/node/522
Dzmitry is offline   Reply With Quote
Stock FA20 block - Force Induction RG4L Forced Induction 42 10-31-2020 07:57 PM
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 02:59 PM
Forced Induction OMJM Want-To-Buy Requests 1 12-01-2015 10:21 PM
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
