| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#4439 |
Drives: 2013 BRZ Limited
Does anyone run staggered tire sizes on a square wheel set? For handling? For looks? Found a deal on a set of new tires and was just going to grab them for the rears (245/35/18). But thought about running the 225/40/18 up front.
Thanks Wheels 18x8.5” square et44 Tires F-225/40r18 R-245/35r18
2013 BRZ Limited
#4440 |
Drives: BMW 135i
18x8.5 et 30
How much of an issue would these be with 245 40 18. Listed on the tirerack as a fit but I have serious doubts.
Factory suspension camber bolts and -1.5 camber up front. 2019 BRZ with the brembo brakes. Search revealed one with the same specs and it poked quite a bit. Thanks |
#4441 | |
Drives: 2015 BRZ
#4442 | |
Drives: BMW 135i
#4443 |
Drives: 2015 BRZ
#4444 |
Drives: English, French, Swedish & Japanese
Why 245/40? 245/35 is near identical to stock rolling diam….
#4445 |
Drives: 2020 Subaru BRZ AT
Hi guys wondering if 18 x 10.5 + 22 all around with 255/35 front and 265/35 rear will fit flush? I know u must run spacers with this setup, but does anyone know how big of spacers?
He is running this exact setup but I don’t know how big of spacers he uses https://ibb.co/9bZZY5f |
#4446 |
After going through these pages I’ve learned a lot!!!
I am currently on stock suspension with no modifications on my 13 BRZ. Just bought some Option Labs R716 18x9.5 +35 offset. Looking to run them on 255/35/18 Firehawks Indy 500 Will these fit on stock suspension? After reading I know 38 offset will rub strut, but hopeful I’ll be ok with 35 offset |
#4447 | |
Drives: 2015 BRZ
#4448 |
Thanks for letting me know, lowering the car will be my next project but for now this all I can afford. Maybe in 3-4 months.
#4449 |
Drives: 2015 BRZ
Sure np, if you do end up getting that wheel and tire spec. id just going with coilovers so you dont have to worry about clearance issues, just fyi.
#4450 |
Drives: 2014 Toyota 86 GTS
going crazy reading hundreds of posts, so thought would ask here.
Looking at Rota Titan R's in Matt Bronze. In Australia, these only come in 17x9 +38 Car will be on stock suspension, might later on go with TRD lowering springs at most. No plans for coil overs/camber etc First question is, will these sit flush, and then whats the best size tires to make sure no clearance issues and no negative impact on drivability. Both on stock suspension and if i go with lowering springs down the line? Or Rota also do the Titan F here in a 17x8 +42. Is that a better size? Only difference between Titan F and R from what i can gather is more aggressive spoke angle on the R and different sizes |
#4451 | |
Drives: 2015 BRZ
#4452 |
awesome, thanks
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
