Old 05-26-2022, 05:10 PM   #1
ajacob
ajacob's Avatar
Drives: 2020 BRZ
Best floor jack/jack stand for 2020 BRZ
Hey everyone, could somebody recommend a reliable/moderately priced floor jack and jack stands for my 2020 BRZ? Looking to get decent clearance for basic oil changes and changing out for aftermarket unequal length headers etc. Something that is extremely sturdy is my preference, don’t want my car falling on top of me lol Thought of getting wheel cribs, but I do wanna change for new coilovers and wheels at some point.
ajacob is offline   Reply With Quote
Old 05-26-2022, 05:30 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I'm happy with a Harbor Freight 3 ton low profile jack - it's easy to reach both the front jacking point and the diff. On the other hand, they seem pretty pricy right now. I bought mine a few years ago for less than $100.
For jack stands I have two sets of Torrin 3 ton (4 stands in total) with rubber pads from eBay that work well. Again they are going for twice what I paid for several years ago.
With the rubber pads on the stands the jack can lift the car to almost the top height of the stands and that gives adequate clearance with a creeper and great clearance from the floor, about 17".
Old 05-26-2022, 07:05 PM   #3
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I'll second the harbor freight jack, but I went with Esco 10498 stands.
https://esco.net/product/3-ton-perfo...ck-stand-pair/
Rock solid is an understatement.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-26-2022, 07:40 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I also use one of the harbor freight low profile 3 ton jacks.. do not buy harbor freight jackstands though
Old 05-26-2022, 08:31 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I use 6 ton stands that max out at 24.5" of lift. With a 2 ton low jack.
Old 05-26-2022, 09:47 PM   #6
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Pittsburgh aluminum (Harbor freight) is good to take anywhere. I use some wood planks to make sure that car have enough clearance.
Do not cheap out on the stands, it is not worth. Get esco, torin or something like that
Stonehorsw is offline   Reply With Quote
Old 05-26-2022, 09:48 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
why? because of 2 pesky recalls? there's more documented damage from the valve spring recall than any of the HF recalls...
Old 05-26-2022, 10:06 PM   #8
DarkPira7e
DarkPira7e's Avatar
Any safety recall involving some that's only purpose is to protect me from certain death is enough to prompt me to avoid
Old 05-26-2022, 11:14 PM   #9
soundman98
soundman98's Avatar
so you don't buy a hyundai, ford, chevy, or toyota product?
Old 05-27-2022, 07:18 AM   #10
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
For maximum safety, quickjack. I've gotten the car on four jack stands before and never had an issue but having build in mechanical locks and not lifting half the car at a time is really, really nice.
For quick oddball things, daytona 3ton low pro and a bunch of non-HF stands I've collected over the years.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 05-27-2022, 09:08 AM   #11
DarkPira7e
DarkPira7e's Avatar
I have a chance of surviving a car crash with defective equipment. Any failure from the jack stand is most definitely going to kill me if I am under the car. I know you're making a point, but it's not comparable
Old 05-27-2022, 09:53 PM   #12
soundman98
soundman98's Avatar
i've never trusted any jack stand by themselves. well before any recall.
if i'm taking a tire off, i'm putting it under the car. i'm also putting the jack under too-- sure, it might fall over, but it's another layer of protection.
of note, HF is the only company that's recalled jackstands, despite much documentation to the fact that the same factories are churning out the same products with a different sticker for other brands on it.
what concerns me much much more than the hf recall are the other brands using the same factories and same tooling that never issued a recall.
Old 05-28-2022, 09:53 AM   #13
Ohio Enthusiast
Drives: 2018 BRZ
Same here - I have two floor jacks and I leave one under each lifting point once the weight is supported by the stands. I also made a small wooden cube out of scrap 2x12 that I put next to me when I'm working under the car.
A valid point, but keep in mind that when manufacturing in China you typically can specify the level of QC you want (and pay accordingly (and keep a close eye on the manufacturer so that they adhere to your QC level)). The HF recall was blamed on worn cast iron molds, so I can easily imagine the new molds being used for the pricier brands and as they wear out moving down the line to the budget brands.
Still, it did make me wish I bought stands with a locking pin...
Old 05-28-2022, 10:36 AM   #14
soundman98
soundman98's Avatar
yep. though 'who is the better' brand in that scenario is the big question.. i went down a rather large rabbit hole looking for alternatives when the first recall came out. there's no apparent difference in quality to a number of other brands of similarly styled jack stands.
so barring buying and testing every single one to the point of failure, there's no guarantee that any of the other similar designs are a higher-tier or lower-tier that the hf variation.
knowing china, they likely are still using the hf molds on a different product with lower standards...
and of note-- the 1st recall was to address worn molds, the 2nd recall was to address a weld penetration issue--they clearly didn't have the machines calibrated correctly. so while there were 2 recalls, they were for different parts of the assembly, and 2 drastically different issues.
Jack Stand Placement Robert97 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 03-08-2022 08:52 PM
Changing oils by myself, are these a recommended jack+jack stand? btan219 BRZ First-Gen (2012+) — General Topics 67 10-23-2021 04:54 PM
Max Jack Stand Size? Hamza Scion FR-S / Toyota 86 GT86 General Forum 16 04-05-2021 10:10 PM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-27-2015 12:03 AM
Jack stand points xxscaxx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-12-2013 10:01 PM
