Old 06-11-2022, 04:27 PM   #1
jacky831
jacky831's Avatar
Drives: 2016-brz
brz track day high oil temperature question
I participated in a track day event at the weekend, the weather temperature was 77F (cloudy), after 5 minutes of intense driving on the track (due to the track design, most of the 2nd gear was used), the oil temperature went from 200F to 270F (Oil Cooler Sandwich Plate sensor read(DEFI oil temperature sensor),OBD interface reading is 250F), the water temperature is 212F, my vehicle is installed with perrin oil cooler and Koyorad Racing Radiator, and the oil used is redline 5w30. I searched in the forum, and it seems that the phenomenon of oil overheating after installing oil cooler is relatively rare.I found that Everyone's oil temperature at the track doesn't exceed 240F, so is it normal for my vehicle to be warm under these conditions?
Other tests:
(1)I tried to maintain 6500 rpm in 2nd gear for a few minutes, and the oil temperature also reached 270F from 200F (the engine does not have any DTCs)
(2)During daily city road driving, the temperature is stable at 194F: the oil temperature is 194F (Oil Cooler Sandwich Plate sensor read), and the water temperature is also 194F
jacky831 is offline   Reply With Quote
Old 06-11-2022, 05:37 PM   #2
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Something's not right. Maybe the sandwhich plate (being thermostatic) is stuck.
kevaughan is offline   Reply With Quote
Old 06-11-2022, 05:55 PM   #3
jacky831
jacky831's Avatar
Drives: 2016-brz
I used hks oil cooler-na before(The temperature is still very high after changing the perrin oil cooler), I also suspected that the sandwhich plate (being thermostatic) was working abnormally, I took it out and tested it with hot water, after testing I found that they work well
Old 06-11-2022, 06:05 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you boosted now? Where do you have the oil cooler mounted?
I’ve seen oil temps up near 270 before on my car NA w/oil cooler. Much higher ambient temp though. I moved my oil cooler from the lower tray to the crash bar. Gets more direct air flow. Do you have a hood duct?
Old 06-11-2022, 06:20 PM   #5
jacky831
jacky831's Avatar
Drives: 2016-brz
My car does not have a boost, and it is currently in the original NA state. I installed my oil cooler in the middle of the front of the water tank (installed according to the perrin official instruction manual), there should be a relatively direct airflow. I haven't installed the hood duct, I found someone saying that the oil temp will drop by 50F after installation, but I'm not sure if that's true
Old 06-11-2022, 06:54 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d say the defi gauge is not reading right. I see about 200f water temp with my koyorad. My Innovate gauge was showing 220. 250f oil temp from your OBD2 is not bad. I typically see 230-250 depending on ambient temp. My temps dropped a lot after moving my oil cooler up. I noticed mounting it to the lower tray masks a good amount of it.
Old 06-11-2022, 07:21 PM   #7
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
I would trust your OBD reading of 250 and that is not bad. Where are you reading oil temp from your other gauge? 270 pre oil cooler is not terrible ether.
Old 06-11-2022, 11:48 PM   #8
CSG Mike
CSG Mike's Avatar
The Perrin oil cooler in my experience is usually not sufficient for track driving, if you're carrying any kind of speed or higher RPMs.
Jackson Racing bare minimum (which has ~50% more cooling), GReddy preferred (~125% more cooling)
Old 06-12-2022, 03:22 PM   #9
jacky831
jacky831's Avatar
Drives: 2016-brz
I installed a defi oil temperature sensor at the Oil Cooler Sandwich Plate, and then I saw using the defi gauge.I saw the information on the Internet, it seems that the maximum working temperature of 5w30 is 266F.
Old 06-12-2022, 03:24 PM   #10
jacky831
jacky831's Avatar
Drives: 2016-brz
I've tried changing gauges from other brands, reading through the Oil Cooler Sandwich Plate sensor, still the same. Thanks for your reply, I will consider trying to move the oil cooler location.
Old 06-12-2022, 03:27 PM   #11
jacky831
jacky831's Avatar
Drives: 2016-brz
I installed hks oil cooler before using perrin oil cooler, the official description of hks mentioned: "This is a cooler for racing", hks has 15 rows of coolers, it seems to be more than greddy, but in mine There is not much difference between the temperature of hks and perrin on the vehicle, and there is still a problem of high temperature.
oil temperature, track
Car won't start, engine coolant high temperature? TeaFee Issues | Warranty | Recalls / TSB 28 07-17-2021 09:00 PM
Question about track oil temperature, pressure, and viscosity mkodama Tracking / Autocross / HPDE / Drifting 5 10-15-2018 05:34 AM
GTA high temperature silicone coating FLYFISHR CANADA 4 12-28-2017 09:20 PM
Tire Pressure and Temperature Gauges recommended for track use Toyarzee Tracking / Autocross / HPDE / Drifting 16 01-26-2016 09:23 PM
Frs temperature gauge question Young_makaveli Engine, Exhaust, Transmission 11 01-03-2014 06:25 PM
