Old 08-04-2022, 10:19 PM   #491
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hey, guys, if you're going to drop and reinstall your pans, please be careful about keeping the RTV away from the screw holes, especially if they are closed at the bottom.
I learned the lesson as a kid when I ruined a casting by ignoring the physics of incompressible fluids. Cracked it wide open lengthwise along the cavity.
I know it's a challenge, but this can kill the most valuable parts of the engine if the RTV has nowhere else to go.
I have seen it too, mostly on motorcycle cases.
Where is that picture from? Procedure is to apply to the lower pan, not the upper pan.
Old 08-04-2022, 11:03 PM   #492
orly? Look back a couple pages for source. I didn't want to make a big deal but, yes. a few oopsies.
Old 08-04-2022, 11:36 PM   #493
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Potential Cause of rumored GR86’s blown engine? Seal packing(RTV) was peeled off
No I am wrong, it is the upper assembly that gets the FIPG applied.
Old 08-04-2022, 11:40 PM   #494
I was too lazy to verify. I only suspected it. Shame on both of us.
Old 08-04-2022, 11:56 PM   #495
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Engine is always upside down on the stand.
Old 08-05-2022, 12:37 AM   #496
gcmak
gcmak's Avatar
Drives: GR86
Definitely curious about the silicone in the screw holes but Justin seems to have experience on quite a few cars including the last gen.
gcmak is offline   Reply With Quote
Old 08-05-2022, 01:02 AM   #497
soundman98
ProCrastinationConsultant
soundman98's Avatar
that's great, do it yourself. but how do you know you're not applying even more and creating the same problem all over again?
the question i still don't understand is why doesn't everyone make their own gasket for this?!?
it appears to be 2 singular parts touching, so there's no extra sealant needed to seal the seams between engine halves... so grab some gasket material, and cut to fit...
Old 08-05-2022, 01:41 AM   #498
Liquidsnake
Drives: "I drives like a Porsche"
We are all fd in the A!!!!!
Liquidsnake is offline   Reply With Quote
Old 08-05-2022, 02:43 AM   #499
Ronac
Drives: Gr86
He probably added more silicone than was there in the first place…
Also, the silicone that gets stuck in the pickup doesn’t only come from the oil pan. It can come from the front timing cover mating surface as well. It can continue to break off from there and plug up the pickup.
Ronac is offline   Reply With Quote
Old 08-05-2022, 02:55 AM   #500
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
We really need to figure out how to inspect and clean the oil pickup tube without taking the oil pan off.
Someone on FB posted that his Subaru techs were able to take a photo of his filter mesh without taking the pan off.
Follow the build thread for my GR86!
Old 08-05-2022, 03:14 AM   #501
mycrors7
mycrors7's Avatar
Drives: zd8 brz
yea see that's impossible.. like physically impossible, especially at the angle that photo was taken
mycrors7 is offline   Reply With Quote
Old 08-05-2022, 03:20 AM   #502
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Great catch, that photo was clearly taken from a few inches "down" from the tip of the pickup tube!
Old 08-05-2022, 03:24 AM   #503
Way too much is being made of this. I don't endorse this preemptive DIY disassembly of the engine. I certainly don't endorse publishing amateur youtube videos of sloppy work, but it's a free internet. Have at it.
Old 08-05-2022, 04:13 AM   #504
mycrors7
mycrors7's Avatar
Drives: zd8 brz
Tbh all someone has to do is weld on a bung right where the oil pickup is and have a plug there. Drain oil, pull plug, use long pick to clean out the excess rtv, plug it up and repeat every oil change as a precaution
Or just full send cause it being a Subaru boxer it’s likely going to go kaboom one way or another
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
