Old 05-29-2020, 03:56 PM   #15
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
As in sideways movement? In what situations? During cornering?
Likely with the wheel pointed straight. Point the steering wheel straight, and the whole car just goes diagonally sideways.
Old 05-29-2020, 03:58 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Old 05-29-2020, 04:11 PM   #17
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
What exactly is crabwalking? Sometimes I struggle to find a word for a handling symptom so I’m curious which one that is
As others had stated I had to fight to keep the car straight or else the rear and front of the car would drift to the right lol, as if steering from the rear.
A symptom of having insane toe out on the right side of the car and toe in on the left side.
Wasn’t a fun drive to the alignment shop
JBezugs is offline   Reply With Quote
Old 05-29-2020, 04:12 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
KW/ST seems to be the go-to comfort/sporty setup these days across many chassis.
I'd pick one of those two, or Bilstein or Tein over BC if you're looking for street comfort.
You could probably also get a nice ride quality improvement with a set of Koni Yellows paired with your current lowering springs.
ineedyourdiddly
Old 05-29-2020, 04:26 PM   #19
norcalpb
norcalpb's Avatar
The way to get good ride quality and performance:
1. Travel
2. Quality valving
3. Reasonable spring rates
All of those are important. If you REALLY screw up 1 of them you're in trouble.
So let's start with travel. From the factory these cars have pretty decent TOTAL travel. But a lot of that is droop (extension) travel and not compression (bump) travel. You're almost on the bumpstops at rest by design. With most lowering springs, you're already compressing the bumpstops before you hit a bump. It's a serious limiting factor when it comes to both performance and comfort if you want more than a mild drop on lowering springs.
You obviously need travel to soak up bumps and for mechanical grip (harsh spikes in load from bottomed out shocks is bad). It's important for comfort and handling.
Coilovers are usually designed with a drop in mind from the start, so that's good. You sometimes get more bump travel at a lower ride height...at the expense of limited droop travel. Both are important. Unfortunately travel numbers are rarely advertised by anyone. Our RCE coilovers have about 142mm of total travel in front, about the same as same as OEM and more than most coilovers. You end up with more compression travel than stock at our recommended ride heights with a still good amount of droop.
You'll often see separate ride height and spring preload adjustability advertised. This is IMO almost always misunderstood and misused even by suspension companies. MCA in Australia is one of the few places I've seen that gets that it's more about ratio of bump to droop travel than anything else (and in practice it's usually a cost-saving measure).
Valving is also something you don't see in marketing and can be difficult to interpret anyway. Things like linear, digressive, and progressive valving are generalizations that are tossed around but there's much more to it. Digressive is usually thought of as the ticket for street and circuit driving, but there's a lot of nuance beyond that. There are plenty of crappy shocks out there with digressive pistons, or shocks with good quality components that are just valved poorly. For comfort, the enemy is mostly excessive rebound...especially with limited travel. Rebound is the force from the damper that tries to hold up the wheel after it compresses. It acts against the spring extending and has to be designed with that in mind. Lots of rebound with a softer spring can lead to packing down, which means the damper is holding the wheel up too much. The wheel doesn't extend in time for the next bump, so you have even more limited bump travel and it just gets worse.
This is by far the most complicated part. It takes some math to figure out where to start and with the way dampers function over different kinds of inputs...it can do well in certain situations and worse in others. An adjuster can help dial things in but sometimes you're limited in your range OR there is no 1 good setting (the range might be from soft and crappy to stiff and crappy, with nothing but crap in between). Shocks are complicated.
Spring rates are IMO kind of the least important of the three, but all 3 do have to work together. A really good set up can have spring rates 3 x as stiff as stock and still ride better than stock if it has good valving and travel. But they have to be dialed in. There are rules of thumb about appropriate spring rates for different applications and tire choices that are usually a good start. Stickier tires need stiffer springs is the short version. But a lot of those formulas are just that...a good start. Testing and experience will have you shifting things a little in either direction to get the most out of the car on track or to find a good compromise for different usages.
Anyway, that's just the start of things really. Happy to answer questions here or by PM or give us a call to chat. We have our own springs and coilovers, and also sell a few other brands that we have learned to like in our almost 20 years in Subaru suspension. We're also not afraid to say when another company makes a good product that we don't sell. We just like good suspension.
- Andrew
Hey Andrew I had a question about travel in the rear. I know that spherical bearing based rear top hats add over an inch of travel, but I was wondering if this additional travel provides enough comfort to override the fact that there's not a soft bushing top hat anymore.
Old 05-29-2020, 04:58 PM   #20
strat61caster
in my experience the factory top hats (both front and rear) are really stiff to begin with and the nvh increase from a high quality spherical is negligible compared to changing spring rate and damper valving.
ineedyourdiddly
Old 05-29-2020, 05:32 PM   #21
^Yeah the rear OEM mount especially does not have much give so there's minimal difference there. For the front, a high quality spherical bearing top mount will have a slight impact on ride quality.
- Andrew
Old 05-29-2020, 05:47 PM   #22
norcalpb
norcalpb's Avatar
- Andrew
Do spherical bearing rear top hats raise or lower the car at all? I’m on springs/shocks and I’d like to keep the ride height where it is at.
Old 05-29-2020, 06:40 PM   #23
ls1ac
ls1ac's Avatar
Just to clarify the video of the truck, this happens when the rear axel shifts on the springs. Rear wheel drive with solid axels.
Old 05-29-2020, 07:49 PM   #24
CSG Mike
CSG Mike's Avatar
all the time
Old 05-29-2020, 08:37 PM   #25
strat61caster
Depends on the design and how they locate the spring perch. You have to email the manufacturer of the part to get the answer to your question if they don't publicize a ride height change or dimensions for you to measure.
ineedyourdiddly
Old 05-29-2020, 09:53 PM   #26
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Most of the basics have been covered, but if you really want to go low for aesthetic reasons and have a reasonably good ride & still handle well I'd suggest RS*R Black-Is.
I personally run HKS Hipermax GTs but my ride is slightly crashier than I'd like with how low I am. Although I still MUCH prefer my setup over the OEM performance pack suspension my car came with. If I raised up 0.5" my car would ride like a dream, but my inner fitment perfectionist won't let me...
Shizuka is offline   Reply With Quote
Old 05-29-2020, 10:03 PM   #27
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Bags.
Old 10-05-2022, 02:15 PM   #28
Swisher Seattle
Drives: 2017 BRZ LMT w/ performance Pkg
HKS HIPERMAX S is the best choice
Swisher Seattle is offline   Reply With Quote
coilovers, comfort, performance parts, suspension
Comfort Performance KW v3 vs HKS Hypermax IV GT Tedderple Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-04-2020 01:34 AM
SACHS Performance coilovers Shark_Bait88 Brakes, Suspension, Chassis 2 04-22-2017 10:33 PM
Bilstein B14 Coilovers: Want to hear some reviews about ride comfort ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-17-2015 04:12 PM
ARK performance DT-P Coilovers (TESTING) 20valvewynn83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 05-13-2013 09:23 AM
