Old 12-04-2022, 04:17 PM   #1
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
2022+ Brake Pad experiences
Hello, first post here but I have been reading a ton of past threads on here thanks to the wealth of information. New to this platform, but not to many others.
I've obviously seen reviews of various G-LOC/Carbotech/etc threads on here, but wanted to get a feel for what people are seeing on the 2022+ chassis for various pads. If the ST43/5 were available, I'd def just buy those but I can't seem to find them in stock anywhere. I have seen some recommendations for CSG pads esp for the life but not quite sure if I want to drop that much on a set of pads before getting a feel for consumable costs on the stock brakes as I feel that may just push me to the same point as I was on my S2K where I just went for an AP BBK.
So I guess my question is, has anyone experienced fade on the newer gen (or 1st gen at 2nd gen power levels) on, say, an XP12 F/R or R12 F/R? Consider fluid aside as I'll be going to SRF, and an average seasoned driver (links if it helps of s2k days, car was prob Nasa TTC, stock power/RS3's, GTC200, Koni-gc setup):
1:21.1@Roebling - https[:]//www.youtube.com/watch?v=QPaLiJtazbA
2:33.5@Sebring - https[:]//www.youtube.com/watch?v=VqkSw0K9sv0
I will be staying stock power and on street tires (whatever variant is the best bang for the buck at the time, RT615k atm but something similar). The goal is to stay as stock as possible as I kinda want to see what is most competitive in my area, but I absolutely can't stand driving around brake fade or fluid temps as it detracts from focusing on driving. So, worst case I'll go to a BBK but otherwise I'd like to just stay on the stock brakes.
I appreciate any input! Thanks!
Last edited by nissanfanatic; 12-04-2022 at 04:25 PM. Reason: Posted videos as simple links. Embedded frames are kinda obnoxiously large....
nissanfanatic is offline   Reply With Quote
Old 12-05-2022, 04:29 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Probably all the info/feedback on brakes you find in context to Naturally Aspirated gen1 on the forum (regardless of being stock or FBO E85) will apply to the gen2. They aren't so drastically different from each other in weight and power.
I had Project Mu Club Racer on the factory sliding calipers and never had an issue with fade. If you have eyes on Carbotech XP12 / R12, I doubt you'll have any fade issues.
As far as longevity, the fastest wearing item on the base sliding caliper system is the front pads and rotors: you might expect to average 8 track days out of the fronts / 14 out of the rears before the pads are down to backing and rotors are below min thickness on a compound like XP12. This will vary a with specific rotor and compound, but I think it a decent frame for wear expectations.
  • The FRS/86/BRZ factory brake system seems to be more friendly on consumables compared to s2k factory single piston brake system, based on conversations I've had with folks familiar with both platforms.
If you have eyes on optimizing long-term consumable cost, it's probably ideal to tackle only the front for BBK upgrade. Rears already last so long and perform fine in their stock sliding caliper form. I just put 9 track days on my front Brembo 326mm BBK and CSG C21 pads; they seem like they'll be good for 18-20 total track days at their current attrition rate.
EndlessAzure is offline   Reply With Quote
Old 12-05-2022, 10:59 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did you try Porterfield for the ST43/45's ? That's where I got mine last.
Old 12-06-2022, 11:45 PM   #4
nissanfanatic
Drives: 2023 BRZ
I have not, but I will definitely check. Had just given up based on reading recent threads that they were out of stock with no end in sight.
Thanks to both for the input!
Old 12-12-2022, 06:33 PM   #5
CSG Mike
CSG Mike's Avatar
The BRZ has substantially larger pads than a s2k, with less weight.
Try the C1/C11 on your 2022+, and it'll easily pay for itself.
Old 12-26-2022, 06:45 PM   #6
nissanfanatic
Drives: 2023 BRZ
Well, sorry @CSG Mike I didn't get the C1/C11, but I did order a set of XP12/XP10 through CSG. Figured I'd go cheap for my first set on this car and see what I think of the system overall.
Old 12-26-2022, 06:56 PM   #7
CSG Mike
CSG Mike's Avatar
If you're able, I recommend you go square compound with Carbotech.
The C1/C11 stagger isn't for friction, but for response. Going staggered with Carbotechs will result in abnormally fast front pad wear.
Old 12-26-2022, 07:34 PM   #8
nissanfanatic
Drives: 2023 BRZ
Thanks for the heads up; just emailed to change it.
MA86 ANNUAL CAR SHOW - PUB DOG: THE BIG ONE 2022 - September 18, 2022 in Columbia, MD JakeRogue Mid-Atlantic 41 10-03-2022 08:37 AM
Not Another Brake Pads Thread 2022 Edition SlowCarFast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 03-01-2022 03:19 PM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 12:44 PM
What brake improvements were made for 2022? Up4speed BRZ Second-Gen (2022+) — General Topics 5 01-08-2022 11:52 PM
