Old 06-25-2021, 12:21 PM   #57
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
It was a long time ago I ran 5-30, I want to say it was similar I don't remember.
I notice the pressure drop pretty much at operating temp or above.
Gotcha, and your operating temp is considered to be 212F? Or 176F per FSM?
Dzmitry is offline   Reply With Quote
Old 06-25-2021, 02:05 PM   #58
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
180F+
Old 06-25-2021, 02:58 PM   #59
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
@Dzmitry I should have some good data coming up. I am using Innovate Motorsports MTX gauges going to a sensor interface and a logger. So I will be able to log and plot temp/pressure and RPM. I was trying to get it done last week for my last track day, I just ran out of time to make a harness to pull RPM reference from an ignition coil. The data will get posted up in a new thread. I plan to test 0-20 and 5-30 with and without oil cooler over the course of this year. I just have to find the time. I still need to swap the radiator on my car, and pull the engine and reseal the timing cover and install the rocker retainer kit. Those take priority.
Old 06-25-2021, 03:01 PM   #60
Dzmitry
Dzmitry's Avatar
That would be awesome and very informative, looking forward to it!
Old 09-27-2021, 10:28 PM   #61
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Any update on this data set?
Thank you!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 09-27-2021, 10:58 PM   #62
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thank you!
Can’t get it to communicate properly.
Old 02-10-2023, 06:48 AM   #63
J95
J95's Avatar
Originally Posted by DarkSunrise View Post
That's true, but not all oil coolers are built the same. Generally speaking, a narrower width oil cooler with more rows (taller) will have much less of a reduction in oil pressure.
http://www.setrabusa.com/products/oi...ine/index.html
Same for larger oil lines with gentler bends. The goal is that the oil cooler reduce temps to a large enough extent to more than off-set the small drop in oil pressures that it causes.
A little spitball math here. The Setrab link above shows the pressure drop across a Setrab 613 is around 4 psi. In my experience, a typical front-mount Setrab 613 setup (Perrin, Racer X, etc.) will reduce oil temps by about 40 F on this platform. From the pressures shown on this link, that means a 613 will still add another 16-17 psi oil pressure at 7000 rpm (assuming 235 vs. 275 F oil temps).
https://www.ft86club.com/forums/showthread.php?t=91820
So it's still adding a net benefit despite the fact that the Setrab 613 IMO is a pretty marginal setup on this platform (without doing something to increase its efficiency like a vented hood). From what I've heard, a well designed 19 row cooler can drop oil temps on this platform around 50 F.
Hey! I just found this comment which I find very useful, but I am confused about the psi drop table and the radiator size. How come is that more rows means less pressure drop? i.e 610 has 4.8 psi drop vs 613 has 4.0 psi drop
Basically I am debating between a setrab with 10 or 13 rows because I am concerned about overcooling in daily use and the 10 rows could be beneficial here. I make mix usage and right now I see easliy temps of 135° on the track, so an oil cooler is for sure needed (will keep NA)
J95 is offline   Reply With Quote
Old 02-10-2023, 08:59 AM   #64
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
More rows means there are more passages for the oil to go through. Think of it as a larger hose. With more passages the oil is flowing slower giving heat exchanging more time to work. You are better going with more rows than longer oil cooler.
Old 02-13-2023, 06:19 AM   #65
J95
J95's Avatar
Ok thx!
I am deciding between 10 or 13 rows. It will be placed in the front bumper.
My car is NA and I have mixed usage road/track but I am really concerned about overcooling in winter so I thought about going for 10 rows. Any thoughts on this?
Old 02-13-2023, 11:27 AM   #66
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Ok thx!
Get a thermostatic sandwich plate and you don't have to worry about overcooling. Regardless of winter, you should use a thermostatic plate anyways.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Another thread about Oil Temp and Pressure Gauges Shady195 Engine, Exhaust, Transmission 2 06-25-2019 01:51 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
