Old 03-15-2023, 11:32 PM   #4789
StevetS
StevetS's Avatar
Drives: 2013 FRS
@CSG Mike
@StevetS
The information is not available online, because it is (what should be) common knowledge for tuners.
You could have, also, just called Edelbrock for that info.
You can't just replace the MAP on the Edelbrock kit, because it's a TMAP.
Have you considered using a different tuner that has substantial first-hand experience with the kit?
I would have thought it was common knowledge too. Had I known this was going to be such a big ordeal, I would have called them before my appointment. However it was about 7PM on a Friday evening before I realized they weren't going to be able to "find" the info they needed.
I did buy a 3 bar Bosch TMAP today with the same 4 pin connector as the 2.5 currently on there. Part number 0 281 002 845. I called Bosch a few days ago to figure out what a good sensor number would be and they were beyond unhelpful.
I have considered this lately. This was my first time ever tuning a car and I've learned a lot about questions to ask a tuner before the car ever gets there. There is a Subaru specialist here in Orlando that I've heard good things about. However they've already put the license on my ECU and have ran the car on the dyno already and I owe them money for that.
I even looked at CSG since I have your MXP touring exhaust on my car. I only went to this shop because they were a referral from someone here who knows cars.
StevetS is offline   Reply With Quote
Old 03-16-2023, 01:38 AM   #4790
Decep
Drives: 2013 FR-S Series 10
Run, run ruuuuun away from that shop.
Just have Zach e-tune it. There are some gentlemen on this forum who are competent e-tuners as well, you can see their posts in the software/tuning section of the forum
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 03-16-2023, 02:47 AM   #4791
CSG Mike
CSG Mike's Avatar
Originally Posted by StevetS View Post
@CSG Mike
Remember that the FA20 and FA24 are unique engines that have essentially ZERO actual tuning relation to any other engines Subaru make. The injection system isn't even Subaru; it's Toyota. Run far, far away from any Subaru shop that says they can build/tune/whatever A BRZ/FRS/86/GR86 because they're a Subaru specialist and the BRZ/FRS/86/GR86 is a Subaru. No good 86 shop would ever say they're a Subaru (or Toyota) specialist. They're strictly a 86 specialist.
Bosch will not be helpful; their target customers are not consumers but rather, OEMs, manufacturers, suppliers, etc.
Old 03-16-2023, 04:16 AM   #4792
tomm.brz
Drives: brz 2017 hksv2
i'm posting here the 2.5 TMAP values that Edelbrock itself uses on their carb tunes, as this whole secret-circle and mystery cloud around these things needs to stop
Pressure Offset: -0.0165 (bar)
Multiplier: 0.543 (bar/V)
min V: 0.01
max V: 3.91 (can be raised)
as far as i know, they don't touch the Air Intake Sensor scaling, so probably the oem scaling of the temp side in the maf is good enough for the temp side of this new TMAP
Old 03-16-2023, 11:32 AM   #4793
StevetS
StevetS's Avatar
Drives: 2013 FRS
Lightbulb
I'm feeling like that too. I feel like I may be able to pay them for the license which they have put on my ECU and tell them to piss off about the wanna-be half tune they gave me.
I actually didn't realize Toyota really had anything to do with this engine. I wish I would have become an active member on this forum before I started this tune endeavor. Thanks for sharing your knowledge!!
min V: 0.01
If only we could have found this exact post last week when I was sitting in the tune shop scouring the internet. Thanks for posting this!
Old 03-16-2023, 04:06 PM   #4794
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I'll echo everyone else and say get a new tuner. Last thing you want is for someone with zero experience on the platform tuning your car. You'll only have headaches down the line.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 03-16-2023, 04:45 PM   #4795
StevetS
StevetS's Avatar
Drives: 2013 FRS
Absolutely. I'm going to go pay them for my ecutek license and never let them touch the car again. I'll also probably tip the guy who actually tried to tune it, he spent a lot of time looking for the info the shop owner never bothered looking up.
Old 03-17-2023, 12:50 AM   #4796
CSG Mike
CSG Mike's Avatar
Good on you for taking care of the guy!
Old 03-17-2023, 08:38 AM   #4797
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Originally Posted by Brewster View Post
Might be worth checking SOCON's post #4529 on page 324 for a cool way to lift the blower
@Brewster @Muskoka800 @dpfarr @Jeff86 @B_T
I fixed the vacuum leak! Turns out it was the intake manifold gaskets...
I performed a smoke test and closed off the whole system was not able to diagnose the leak, very weird. I was pulling my hair out trying to figure it out when I said screw it, I'm just going to replace the gasket. Well, I'm glad I did that. The passenger side intake manifold gasket had the smallest tear in it which I am certain was causing the leak. I was also certain the last time I seated the SC it was not on correctly. Between either of these two things were the problem.
Car is running very smooth and holding boost pressure strong. Just need to have the tuner adjust my tune. So stoked to drive the car now!!
Thank you all for the help.
GPhilly is offline   Reply With Quote
Old 03-17-2023, 10:40 AM   #4798
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
@GPhilly Glad you got it figured out man.
B T is offline   Reply With Quote
Old 03-17-2023, 12:11 PM   #4799
tomm.brz
Hi @B T do you still build the remote map locator?
Old 03-17-2023, 12:12 PM   #4800
brandonblt2
When you performed the smoke test what line did you connect into? I need to do a test on mine for air leaks also.
Old 03-17-2023, 04:27 PM   #4801
GPhilly
GPhilly's Avatar
I took off the intake box and used an adapter from the smoke tester kit. It was mounted to the diameter of the intake before the MAF.
Old 03-17-2023, 10:43 PM   #4802
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You can make your own with some off the shelf parts from most hardware stores, along with the Honda Civic Denso MAP sensor port adapter from SiriMoto
https://www.procivic.com/pages-produ...048/index.html
I just put mine on earlier today.
Edit: This is for the Harrop application that uses the OEM MAP sensor not the TMAP. There may be port adapters for the Edelbrock-supplied TMAP sensor though, the rest of the parts would be the same.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
