#1653 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
NOVEMBER? Holy crap that's completely unacceptable.
#1654 |
Drives: None
There are two people in the FT86 Enthusiasts Discord (there is a swaps thread under tech-talk) that are in the middle of swapping, both of them got a parts shipment over the last week or two and the harness was included... only thing missing for them is the oil pan
One ordered in late November, the other early December
#1655 |
At the track
Drives: '14 FRS - Former e92 M3
Yeah
I've placed various orders from Black Friday through January. I have gotten most of them but the electronics package is taking forever it feels like.The very first thing I ordered was the Wiring Harness/ECU kit since it was the biggest deal on the Black Friday sale with the Haltech discount being the main bulk of that savings. Plus, I figured it would take the longest of anything else in the kit. And they probably had a ton of demand/orders placed during that time. I ordered the builder kit late-December and got the oil pan and everything else from that fulfilled late-January which I thought was really good. I think what's bothered me most is in the meantime I've seen other people on social media having ordered wiring harnesses/electronics packages more recently than I did receiving their orders... so I don't really understand their fulfillment order at all
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#1656 | |
Wears Pants
I'd post up on the FB group and maybe that will motivate them?
#1657 |
Drives: None
I talked to KPower and they told me to send the harness in to them for repair... so I just got back from mailing it out.
I'm currently feeling a sketch level of about 12 out of 10 for making the events in less than three weeks.
#1658 | |
At the track
#1659 | |
Drives: Fr-s
Which also means no more dragging feet, it's go time!
#1660 |
Drives: 2013 frs
I placed my full swap kit order on black Friday and haven't received a single thing. Sent many emails to kpower asking for updates and all I get back is, "You will be getting a tracking number very very soon" Its been months of hearing that lol.
#1661 |
At the track
If it's any consolation I Finally got my remaining shipping notifications today so hopefully there's light at the end of the tunnel for everyone!
#1662 |
Drives: None
Crossposting this from my thread but the tell-tale for a 74mm Bosch TB dying is that it hiccups during initial acceleration after start and throws codes for something like:
P2109 DBW Throttle 1 Disabled P2145 DBW Throttle 1 Throttle Position Sensor Voltage Correlation P2165 DBW Throttle 1 Relaxed Sensor Mismatch Settings Could also be throttle 2 but I haven't had one fail that way yet. The black strips here are the resistive strips for the internal throttle position sensors ![]() ![]() For whatever reason they are being worn through really quickly, this TB has 6 events or like 400-ish miles on it. Gear teeth are also eaten at WOT position.
#1663 |
Drives: Many
Anyone get a custom carbon fiber driveshaft yet? I'm still waiting on the engine builder and want to get one ordered sooner rather than later. Anyone willing to get me the measurements of their aluminum one?
#1664 |
Drives: 16' WWB
4 Piston Head Update
Dyno time!
I purchased and paid a shop ($2250) to assemble and install a 4 Piston TSX Pro head with some Toda A3 cams, 1. because my original head had leaking valve seals and I was tired of burning oil, 2. because after 15,000 miles I wanted a little more power, and finally 3. because I can no longer work on a car due to needing lower back surgery. Well it just hit the dyno today and here are the results (followed by complete parts list). The red lines are WHP and the blue lines are WTQ The top lines are with the new head/cams on E50 The bottom lines are from when it was originally tuned on stock head/cams on 93 264.3WHP 199.4WTQ Overall from when I first swapped the car to now: +39.6WHP peak +36.3WTQ peak Comparing new head/cams on E50 vs stock on 93 ![]() I don't have an overlay of when I dyno'd on E85 with the stock heads, but looking back at that old dyno sheet, here are numbers for those curious +30WHP peak +4WTQ peak While +4WTQ doesn't seem like a lot, looking at my E85 graph as a whole it makes more torque everywhere in the power band: @3300 RPM +5WTQ @4000 RPM +22WTQ @5000 RPM +4WTQ @6000 RPM +10WTQ @7000 RPM +12WTQ @8000 RPM +18WTQ This is really good news to me because I was afraid I would lose some low end going with these cams and happy to report that the opposite happened which is great because this will always be a daily driver first and foremost. Parts List: 2006 k24A2 from the junkyard - unknown miles 4 Piston TSX Pro Head Toda A3 camshafts Bosch 74mm TB with Kpower adapter (we'll see how long this holds out) Mishimoto Powerstack Performance Air Filter Toda Valve Springs Ferrea Valves OEM retainers, locks, seats Viton Valve Seals Toda Timing Chain Toda Oil Pump Chain Toda Chain Tensioner ARP Head Studs Trac Truf 40 degree VTC limiter (this might have been overkill and may have even robbed a HP or two but I wanted to be safe than sorry) OEM guides DragCartel lower guide I don't have the car back yet but once I do I'll do an acceleration video and compare it to the old E85 setup. Here is the dyno vid: |
#1665 |
Drives: None
Any chance any of you with a v1 engine harness have the harness out of the car? My harness came back from KPower and the thing doesn't read any of the cam/crank sensors and the throttle doesn't work.
Ready to set it all on fire, I've got a day to get it figured out.
#1666 |
Drives: None
Fortunately it was just two mis-pinned wires, it is alive. (they swapped DBW motor 12v and 12v for the sensors)
I had a friend who just got his kit do some multimetering for me, it looks like they changed wire colors for some stuff and moved some stuff from regular ground to sensor ground (dbw went to sensor ground, cam/crank are still regular ground). @funkjaw, I'm really surprised at the power you're making - sounds quite healthy, haha.
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 04:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 02:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 02:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 05:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 02:00 AM |
