#4341 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Does 1st gen RCE yellows fir 2nd gen struts? @Racecomp Engineering
#4342 |
Drives: Crapcan
I don't believe so but I am not familiar with that kit.
#4343 |
Drives: 2023 BRZ, 2018 Golf R 6MT
Anyone know for the front end roughly:
- How much toe changes per degree of camber? Like X amount of added negative camber ~= Y amount added toe in? - How much X amount of turns on the tie rod = Y amount of toe in / out? 2023, BRZ if it makes a difference. |
#4344 |
Drives: 2023 BRZ
I don't remember off the top of my head. But I did post about this a few years ago. Try searching.
Director of Rocky Mountain 86CUP
#4345 | |
![]() - Andrew |
#4346 | |
Track Day Junkie
Drives: 2022 BRZ Limited
How tie rod turns affect toe, toe affecting camber and vice-versa
Pat, can you give us some hints as to what to look for and where in a search? I've tried and have struck out!
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
#4347 | |
Haven't gone all the way through it yet, but is that the one you were thinking of? -Mike |
#4348 | |
- Andrew |
#4349 |
Track Day Junkie
I have created a Google doc that spells this out and could come in very handy.
I'm having people review it before I publish it and I need to confirm the length of the steering arm (centerline of the hole to center of spindle). Anyone?
#4350 |
Drives: It has 4 wheels
I think using the parts shop max kit (raises the rear of the subframe a little more than it does the front) as well as re-drilling the trailing arm bolt hole lower would give you the best of both worlds.
#4351 |
Drives: Crapcan
For classing I am not allowed to alter suspension pickup points. Otherwise MCA traction mod would have happened long time ago.
#4352 |
Track Day Junkie
My takeaway from reading 80% of that long thread from 2017 is that if you have your car significantly lowered "for racing" and have the supporting mods, that it may do little to help.
More interesting to me is if there is a "rear steer" issue with our cars if they are lowered. I have Lime Rock and some others where "bumps" and getting light are an issue and I've already had one issue that seems like it was related to the rear getting light and it snapping on me.
#4353 |
The Dictater
Drives: '13 Red Scion FRS
So went to my first autox event with the new setup. I was pretty happy with the front end, but looking for some ways to get the rear a bit more willing to rotate on throttle.
Current setup: -Lowered about an inch on T2s set to recommended settings -2.3° camber up front, 1.8 rear -0 toe front, 2mm total toe in rear -19mm Perrin front sway on soft Ideas I had: A. Change the front sway bar to the stiff setting. B. Reduce toe in the rear. C. Driver mod.
Also: "Build Thread" |
#4354 | |
Drives: Crapcan
Edit: I forgot you have T2's. Give it a couple more clicks of rebound in the rear.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
