friendly
Drives: 17' 86
Full blown stage one turbo questions
Hello,
I procured a used full blown kit off of this forum and I'd like to get a new oil feed line, should I just look for any -4an line? Also, I have the full blown oil pan, is -10an? Sorry for silly questions just trying to get everything sorted for my build.
Seek comfort in discomfort.
#2 |
Rust bucket enthusiast
Generally -4an in and -10 out is universally the strategy for aftermarket, I have 99% confidence you will be fine with these sizes.
Where are you getting oil from? Top (next to oil gallery or passenger head) or front cover (oil pressure switch)?
#3 | |
friendly
Drives: 17' 86
Turbo is oil only so no need to worry about coolant lines for now
#4 |
Perfect, I imagine fittings were provided but the oil pressure switch thread is 1/8 bspt. Turbo feed is usually 7/16-24
#5 |
friendly
Drives: 17' 86
what do with this hose? help
thanks 8)
#6 |
I cut my hose back, put a small filter on it. It hides partially under my intake manifold and points towards the back of the engine. Never seen anything in the hose or on the filter having it vent this way. You could also get a catch can and then vent that to atmosphere.
Alternatively, you could ask them if they have a turbo intake with a fitting to pull vacuum, I really don't recommend it. I attached a photo of my setup I've been using since I first put a turbo on the car, no issues. Got the filter from AutoZone, came with the plastic elbow
#7 | |
friendly
Drives: 17' 86
Going to run it VTA and do the radium cc with a wrx pcv valve. You're such an asset to the community
#8 |
friendly
Drives: 17' 86
Started up today successfully!
![]() I do have this odd noise that I don't remember having before? https://www.youtube.com/shorts/hlNV1sVt-_I you hear it once the camera gets lowered. It's louder/more noticeable in person. It sounds like it's near driver side injector area/head Am I crazy? @DarkPira7e @Ultramaroon Haven't driven yet waiting for a part for my bumper
#9 |
Not crazy but damn, I have nothing. Sounds like a solenoid/valve trying to engage. HPFP spill control valve wigging out?
#10 | |
friendly
Drives: 17' 86
Wonder if I boinked the injector installl I did recently? is it possible for that to produce the noises? It sounds almost like a clock ticking with an occasionaly double or triple tick. How to check hpfp spill control valve? Edit: think im going to pull direct injectors today just to double check theyre okay
#11 | |
It definitely clocks to something regular/cyclic, but it's really slow! edit: any fault codes?
#12 |
Drives: 2017 BRZ w/PP
Doesn't that hose need vacuum? That goes into my 2nd catch can then around to my intake before my supercharger. Not sure if it has to do with the sound, just taking stabs in the dark.
#13 |
That's a strange noise for sure. What else was changed with this build?
#14 |
friendly
Drives: 17' 86
Direct injector install prior to turbo install, had maybe 20 miles on it? honestly now that I think back I wasn't happy with it because install felt easy but can't remember if it sounded weird or was just running rich STFT/LTFT were high post install (tuner checked logs and said it was fine and would get cleaned up after tuning turbo setup)
Radium PCV catch can and STI pcv valve with drain FBM kit, fbm oil pan, killer bee oil pick up 4an oil feed from where JDL has their feed modified radiator mount bracket to move it forward approx 1 inch for more space from turbo have BOV tee'd into brake booster line WG side port to port on turbo, top port is VTA OMNI 3 BAR MAP base tune
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 04:10 AM |
| Full blown Stage 1 premium turbo kit vs JDL v2.1 | Greenbean | Forced Induction | 11 | 09-05-2019 05:10 PM |
| Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit | FullBlown | Forced Induction | 47 | 06-20-2018 03:38 AM |
| Help full blown stage 1 turbo | h22mike | Engine, Exhaust, Transmission | 40 | 12-08-2014 12:31 AM |
| Full Blown, stage 2 turbo kit | Ironsquid | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 02-18-2014 12:22 AM |
