Old 06-23-2022, 07:52 PM   #211
Ads
Drives: 86
Can anyone confirm that a 2020 Head unit from a Toyota 86 will be a straight plug and play swap into a 2013 Toyota 86 GTS?
Just want to make sure I won't run into any of the issues in this thread:
https://www.ft86club.com/forums/show...2020+head+unit
Also, if the issue with the amp bypass will come into play with this swap?
Cheers all.
Ads is offline   Reply With Quote
Old 06-24-2022, 11:02 AM   #212
Cheers all.
The amp bypass will be an issue since there is no trigger wire on the 2020 unit. The same adapter work around will do the job though.
Old 06-25-2022, 02:48 AM   #213
Ads
Drives: 86
Ok, good to know. Thanks for that Tcoat!
Old 06-25-2022, 09:07 AM   #214
Ads
Drives: 86
Originally Posted by Bobharp View Post
- It seems that those yellow wires and plug is an included accessory to bypass the amp. They just plugged it in.
- Hopefully the photos show as follows;
+ Bypass wire assembly
+ Head unit/speakers plugged into the amp
+ Head unit/speakers plugged into the bypass
+ Rich audio goodness with deep bass via Dire Straits
- So in summary - Just bypass the amp
Originally Posted by MightySouvlaki View Post
Bypassing the amp was worth trying but a quick search for Toyota amp plug part number PT296-18191 shows it selling for an insane $75-$95!
I ordered a Metra 70-1761 harness plug from Amazon for only $5. All you need to do is connect the harness wires then plug it in and enjoy surprisingly decent sound.
I am a bit confused still. For my situation (2020 86 head unit into 2013 86), do I just bypass the amp or do I need the extra harness plug? Or both? Hope someone can clarify. Cheers!
Old 06-28-2022, 10:51 AM   #215
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You can use the antenna amplifier output to turn the door speaker amplifier on. Read my DIY for reintegrating the stock amplifier into 2020 model year twins.
My pubes are shaped like the number 86. There for I知 car. Derp
Count to muffens and call again.
I知 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 07-01-2022, 03:44 AM   #216
Ads
Drives: 86
I'm afraid I'm even more confused after reading through your DIY.. My brain is not working atm..
EDIT - I think I am getting my head around it now. I will create the adapter so I don't have to splice into OEM wiring and then plug in the bypassed plug in the back to the amp. Is that pretty much it in a nutshell?
So I can just buy these adapters:
https://www.amazon.com.au/Metra-70-1.../dp/B0002BEQJ8
I believe the above is the same plug as the Scosche TA02RB? And this:
https://www.amazon.com.au/AUTOHAUX-7...%2C1320&sr=8-7
..is the same as the TA02B?
Old 07-01-2022, 06:01 AM   #217
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Yes to all three questions. Also, you will need the antenna adapters as well.
Keep in mind that those instructions are for a North American model. If your car is an AUS model, some of the wiring MAY be different. In that case, you are on your own. You should be familiar with the use of a multimeter in order to verify the proper connections. I suspect they will be very close to the wiring in the NA models.
Old 08-27-2022, 03:32 PM   #218
oh bui
Drives: 2014 BRZ Limited
Hi All, trying to figure out if this stereo has changed over the past couple of years? I search the same part number and all the local Toyota dealerships selling the unit look different now (more buttons and a volume knob) compared to the images provided where the headunit only has 4 buttons (no knob). Any help would be appreciated!
oh bui is offline   Reply With Quote
Old 09-09-2022, 07:02 AM   #219
trueno86power
[||評=(86)=[怖|]
trueno86power's Avatar
Drives: 2017 Toyota 86
The image from Toyota are not the actual radio. From what I see on a quick google search, the image for this part number are the OEM Toyota 86 17-19 factory radio.
But you will not get this radio, PT296-18190-20 will be the radio with only 4 physical button on the left like you've seen on this thread.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 09-10-2022, 12:23 PM   #220
oh bui
Thanks so much! I figured that was the case but wanted to double check. Appreciate your response!
Old 08-03-2023, 11:45 PM   #221
repillows
Drives: 2013 Scion Frs
Hi guys, still enjoying my 2020 radio in my 2017 86. I've changed my phone (Pixel 4 to Pixel 6) and weirdly now my phone ask me for permission to access my data (like contact etc) randomly. Each time I say yes, but from time to time it pops back.
Nothing crazy, but just want to know if someone else experience that.
Would you be able to attach a pic of the back up camera working with the radio? Thanks!
repillows is offline   Reply With Quote
Old 08-07-2023, 04:19 PM   #222
repillows
Originally Posted by reh8388 View Post
It may be worth adding that this head unit does support reverse camera inputs through the 24 pin connector. The pinout for that connector is the same as the 2016 FRS. I have the unit in my 2016 and the reverse camera looks great on the large screen
Could you attach a pic of the back up camera working on that radio? Also on your 2016, is your back up camera wired into the 24 pin or 28 pin?
Old 11-08-2023, 02:13 PM   #223
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
Can someone help me here? I’m trying to clarify if 2020 Subaru head unit p/n 86271ca690 is a plug and play into 2013 gen1 BRZ? Amp bypass needed but I intend to install a backup cam as well at same time as hu swap. Can I accomplish all?
2013 BRZ Limited WRB
ICEBONEZ is offline   Reply With Quote
Old 11-09-2023, 07:28 AM   #224
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by ICEBONEZ View Post
Can someone help me here? I知 trying to clarify if 2020 Subaru head unit p/n 86271ca690 is a plug and play into 2013 gen1 BRZ? Amp bypass needed but I intend to install a backup cam as well at same time as hu swap. Can I accomplish all?
I can't help with the installation of a back up cam, but I will give you advice on bypassing the amplifier in the back.....DON'T. It will sound horrible if you do. When installing the new head unit, connect the antenna trigger lead from the head unit to the amplifier turn on circuit also (in parallel with the antenna power circuit). This will allow the factory amp to turn on in order to power the door speakers so it sounds much cleaner with deeper and more accurate bass reproduction. All the information you'll need is up to step 16 in post #1 of this DIY thread, including an explanation of what it addresses.
https://www.ft86club.com/forums/showthread.php?t=145959
If you scroll down to the second post, you'll find a less expensive alternative procedure to connecting the antenna and amplifier leads together.
Trust me on this, as long as the remaining system is stock and all you're wanting to do is upgrade to the Harman head unit, you'll want to keep that rear amp in play.
audio, head unit double din, mp3, stereo, usb port
2020 86 TRD info? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 18 08-27-2019 03:41 PM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 03:53 AM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 07:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 07:43 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) � General Topics 0 05-24-2012 11:09 PM
