Old 09-01-2023, 05:30 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Oil Pan Baffle Plate. Blue Moon, Moroso, Greddy, Other?
Leaning toward the Blue Moon baffle plate for my Edelbrocked FA20 which sees weekend cruiser and HPDE/Lapping day duties.
All educated opinions/advice welcome. Thx!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 09-02-2023, 12:34 PM   #2
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I would be curious to see what others have to say. I just invested in an oil pressure gauge to see if a baffle would even be helpful. I’m probably just being blind but I haven’t seen much about oil pressure drops due to cornering on the fa20. The fa24 is a different story of course ha
autoracer86 is offline   Reply With Quote
Old 09-02-2023, 01:03 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Exactly. I agree it's fun throwing go-fast bits on your car, but unless you have data showing a problem (presumably low oil pressure in certain situations) and can verify that the baffle actually helped you might be burning cash for no reason.
Granted, there are some fairly consistent recommended parts for street (camber bolts, better tires) and track (oil cooler (with a minority saying they're not needed)) that I would be comfortable putting on my car (and have in fact done so) solely based on the forums' combined wisdom. AFAIK an oil pan baffle for the FA20 is not a strong recommendation and should be installed only if you actually have a problem.
Old 09-03-2023, 01:19 PM   #4
Muskoka800
I am in the process of adding an oil pressure/temp gauge.
I must soon remove the oil pan to resolve its RTV leak and thought this a good time to slip in a baffle plate. Perhaps, by the sounds of it I should just throw that coin into the track tire kitty.
More input welcome. Keep it coming.
Old 09-04-2023, 06:23 PM   #5
Autoxer62
If you're going to put in the baffle, I'd suggest also installing a Killer B pickup (or equivalent). There appear to be two separate issues that require attention, cornering starvation and high rpm pressure drop.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 09-05-2023, 10:10 AM   #6
M0nk3y
Verus Engineering has put together a preliminary design on the FA24 baffle that utilizes a divider plate with a "flapper" so to speak that will keep oil at the pickup tube during high G load.
They have not considered the FA20 yet but I'd like to poll interest somehow to convince them otherwise.
Kyle H. - #89 STX
Old 09-05-2023, 10:29 AM   #7
Muskoka800
The Blue Moon plate has flaps.
I thought Killer-B used to make a baffle plate for FA20 however it is no longer visible in there site. I do have their pick-up installed.
Old 09-05-2023, 10:30 AM   #8
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I might be interested in such a thing for my FA20.
RongTurnRacing is offline   Reply With Quote
Old 09-05-2023, 10:37 AM   #9
M0nk3y
Blue Moon is for prevening slosh into the upper pan. Verus IIRC is trying to target left to right slosh
Kyle H. - #89 STX
Old 09-05-2023, 12:59 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I didn't notice much difference with a baffle. Now that being said, I haven't logged my data, just what I have seen on my gauge. My car also threw a rocker arm and exploded spectacularly 2 sessions in so I don't have a lot of data
Old 09-07-2023, 04:04 PM   #11
justnutsandbolts
Drives: Tacoma
Seen these guys do it first.
https://koruworks.com/make-model/toy...xoCZZsQAvD_BwE
justnutsandbolts is offline   Reply With Quote
Old 09-07-2023, 04:15 PM   #12
M0nk3y
Originally Posted by justnutsandbolts View Post
Wasn't aware it fit the 1st Gen Pan..I thought initially it was only 2nd Gen fitment
Kyle H. - #89 STX
Old 01-25-2024, 09:06 PM   #13
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Going to bump this with thread with my experience after installing a GReddy baffle plate and a Killer B pickup tube.
I was consistently seeing pressure fluctuations on straightaways, the same as @ajc209 reported having with the original Moroso baffle.
This winter I will be removing the baffle plate. I don't want any oiling issues, especially with the extra power coming from the Jackson Racing Supercharger I am about to order, so I am doubtful I will replace it with a differently designed baffle.
Unless someone has one that has proven to be helpful?
BatStig is offline   Reply With Quote
Old 01-25-2024, 10:06 PM   #14
jflogerzi
jflogerzi's Avatar
it appears a accusup system might be the best fix based gen 2 testing.
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Brand new : Moroso oil pan baffle Joesurf79 Engine, Exhaust, Bolt-Ons 5 01-12-2021 11:00 AM
Compatibility: Moroso Baffle and Killer Bee Oil sump Nightflo Engine, Exhaust, Transmission 3 04-27-2019 10:40 PM
Greddy Oil Pan Baffle Plate empower-auto Engine, Exhaust, Transmission 2 03-30-2017 06:08 PM
Moroso Oil Pan Baffle acj47 Engine, Exhaust, Transmission 6 03-05-2015 12:45 PM
Review/Thoughts on Moroso Alum. Oil Pan Baffle? Kiske Engine, Exhaust, Transmission 1 01-06-2015 07:06 PM
