Old 12-08-2023, 02:36 AM   #1359
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I like the new front and rear water lines. Cleaner setup with the AN fittings.
https://www.instagram.com/reel/C0i4K...hhZWM5NmIwOQ==
Old 12-08-2023, 09:07 AM   #1360
M0nk3y
Interesting moreso on the HX Core internal.
Obviously relocating the outlet/inlet opposing means they're most likely going to a single pass HX versus prior which was dual pass (assuming...I haven't looking to my own HX to confirm).
Regardless, would certainly agree the AN Lines are slick
Kyle H. - #89 STX
Old 12-09-2023, 01:11 AM   #1361
Irace86.2.0
It could be just for their track setup. I don't know the advantage or disadvantage of either setup, but I'd imagine single pass would be cooler.
Old 12-11-2023, 06:22 PM   #1362
CSG Mike
CSG Mike's Avatar
Harrop kits are back
Old 12-15-2023, 08:46 AM   #1363
M0nk3y
Assuming pumping flows and everything else are the same (even going into the fins per inch within the HX itself) it would result in less cooling. As well you'd have a temperature gradient across the core itself as water flows from front to rear (or vice versa).
Now with that, they could have been able to increase pumping flow across a single pass to up the capacity of the heat exchanger, or add more fins per inch (at a negative impact to airflow) to increase heat exchange effectiveness.
Or, it can be something crazy like a 3-pass system.
Kyle H. - #89 STX
Old 02-16-2024, 06:54 PM   #1364
Irace86.2.0
Old 02-17-2024, 02:48 PM   #1365
Tatsu333
Drives: 2020 BRZ Sport Tech RS
So if I'm not mistaken, it looks like the most substantial (only?) non-cosmetic changes are a different nose piece to accommodate the larger FA24 throttle body and the inclusion of an uprated fuel pump for the FA24 kit. The carbon air filter housing piece and the red manifold are purely cosmetic.
I can't really tell from pictures whether where the nose piece attaches to the manifold is a different shape than on the old kits, but I don't *think* so. If that's the case, I'd expect that the "new" FA20 kits are identical to the old ones, especially since any change would probably mean having to redo the CARB certification.
Still my favourite supercharger option for the twins! Glad to see they're available again.
Tatsu333 is offline   Reply With Quote
Old 02-18-2024, 12:21 PM   #1366
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
So they waited for carb cert before selling the kit this time?
Old 02-18-2024, 03:59 PM   #1367
Tatsu333
No - according to the video, the CARB cert for the FA24 kit is not done yet. "For our US market, we'll be putting this through a CARB E.O. application just like the FA20 kit."
Old 03-11-2024, 08:18 PM   #1368
Eaton PSI
Drives: 2013 86
Does anyone know if the Harrop SC kit requires a check valve on the brake booster vacuum line?
I bought a damaged 86 with a Harrop SC on it. I pulled the SC off and transplanted it onto another car. I noticed a check valve on the brake booster hose on the damaged car but I didn't remove it and the wreck is now gone.
Do I need a check valve? The Harrop installation instructions don't mention it.
Eaton PSI is offline   Reply With Quote
Old 03-14-2024, 09:55 AM   #1369
M0nk3y
Yes, you'll still need that check valve on the brake booster line.
Kyle H. - #89 STX
Old 03-14-2024, 02:45 PM   #1370
RedReplicant
Drives: None
There is one built into the OEM brake line
RedReplicant is offline   Reply With Quote
Old 03-14-2024, 04:57 PM   #1371
M0nk3y
Harrop's Instructions are slightly unclear - I would concur. They want you to use the OE Line and add a barb'd adapter to make it reach the new SC location on the front side of the snout.
I ended up running a new line, and simply cut out the existing check valve and transplanted it within the new hose.
Much cleaner install
Kyle H. - #89 STX
Old 04-13-2024, 03:58 PM   #1372
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Hello all - I ordered the tuner kit from harrop for my 2020 US BRZ and am about half way through installing when I ran into a bit of a problem - the air box doesn't seem to match up to the stock half on the dirty side (seems larger and the clips don't align) anyone else have this problem?
mikalem is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
