Old 08-18-2024, 06:27 PM   #29
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've driven around this week. No change in the P0341 code. The engine runs really well, good power. Today, I tried use my Ecutek stuff to datalog but I couldn't get it to connect to my ecu. I've read where their cables can be dodgy. I'm going to see if someone in my area has a scan tool. Maybe I can figure out where my issue is without throwing parts at it.
Old 08-19-2024, 01:34 PM   #30
I don't like this. Wish I could attach my OBDLink to verify that your VVT is operating properly (slewing). Do you have TechStream?
Old 08-19-2024, 09:43 PM   #31
blsfrs
blsfrs's Avatar
I don't have Techstream. I was hoping using Ecktek logging would give similar information. I'm going to try my Ecutek again with a newer laptop and also check around my local car community for some help.
The car runs great. No drivability issues at all. This leads me to believe that the vvt is operating correctly and the ecm, for some reason, likes this code.
Old 09-08-2024, 09:12 PM   #32
blsfrs
blsfrs's Avatar
Alternator and bracket
If you do one of these swaps, get the 2022+ alternator AND bracket.
You can trim the old bracket and almost make it work with a 2022+ belt but mine always had a slight squeak similar to the "crickets". RS said to shave the bracket to move the alternator back 1/8" but then I didn't think the idler pulleys would align.
I found a 2022+ bracket thought I was home free. The 22+ alternator is slightly different. I made it work but ended up using a 2013 belt.
The P0341 is still a problem. RS said he is going fly out here to fix it.
Old 09-10-2024, 01:14 AM   #33
makinen
makinen's Avatar
Drives: Toyota 86
https://motor-fan.jp/weboption/artic...nc09_a75i5483/
They did similarly.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 09-19-2024, 02:01 AM   #34
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I ran my FA20 alternator and bracket just fine
Jyn is offline   Reply With Quote
Old 09-19-2024, 02:33 PM   #35
blsfrs
blsfrs's Avatar
What modifications did you make? Can you post a picture or 2?
Old 09-25-2024, 12:34 AM   #36
jflogerzi
jflogerzi's Avatar
watching this thread. May I ask on the cost of the motor?
2013 Series 10 FRS #553
Old 12-04-2024, 07:15 PM   #37
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
reading the thread and hope everything is well
Old 12-04-2024, 08:52 PM   #38
blsfrs
blsfrs's Avatar
Thanks for asking. My car is fixed and I'm waiting for RMS to tune it and then ship it back to Va. The saga of the issue is here:
https://www.ft86club.com/forums/showthread.php?t=154967
Old 12-11-2024, 10:07 PM   #39
blsfrs
blsfrs's Avatar
The saga is over. My FRS arrived home earlier this afternoon.
Now that the FA24 is tuned, the car accelerates like a bat out hell. No dyno printout as the car was road tuned.
RSM is great to work with and stands behind his product. If only certain a customer was a better diagnostician.
Old 12-20-2024, 03:44 PM   #40
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
What ended up being the issue? Ron mentioned to me that he had an issue with a tuner doing something wrong resulting in a cam position issue, was this your problem?
edit: nvm, just saw the other thread lol. defective sensor out of the box, wack. not unheard of though.
removedonut is offline   Reply With Quote
Old 12-21-2024, 11:59 AM   #41
blsfrs
blsfrs's Avatar
In hindsight: NEW = Never Ever Worked.
FA24 swap to a GT86 ? Anything I need be aware of? twasd Engine Swaps 23 01-09-2024 11:28 PM
Viability of complete FA24 swap (motor and ECU)? Tatsu333 Engine Swaps 43 02-18-2023 07:18 PM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
