#29 |
Drives: 17 Asphalt 86
I was able to grab a set of MX72+ from Blackhawk Japan for $380cad shipped. Everything else comparable is 2x-3x the price with our monopoly money exchange rate.
#30 |
Track Day Junkie
Drives: 2022 BRZ Limited
I don't understand the excitement about some pads! Those using MX72+ could get better performance from a Hawk HP+ and at a fraction of the cost. About $125...
RETRACTION!I WAS BITTEN BY THE FAHRENHEIT VS CELSIUS BUG. Hawk does everything in Fahrenheit. I was thinking it was C without checking. I know I could not run HP's on the track. They can't do double-duty if you are aggressively using your brakes. But, they are cheap!
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube Last edited by Scargod; 01-06-2025 at 09:39 PM. Reason: Correction |
#31 |
Drives: '22 brz Sport-Tech
HP+ is just a street pad that can't do track. It appears to be a 300-600 F pad. I would fade those on the street. I am at the upper limit of use for the mX72+ and they are 1382°F pads. I tried Ferodo DS2500 and liked them, but they disintegrated. Also Killed GLoc G6 on track ( yes they are definitely an Autocross pad). HP+ wouldn't even do it on street for me. I have had those previously on another car. The powerstop Z26 pads are as good.
#32 | |
Drives: 2013 Subaru BRZ Turbo
What crazy world are you living in where they don't work on the street? |
#33 | |
I ran HP+ last year, they worked fine for the very light seasons I did, but wasn't a huge fan of them. HP+ are $300cad per set. Not sure why Blackhawk Japan has MX72+ priced so aggressively compared to US retailers but an extra $80 is a no brainer to me. I was told they're made to order(1.5.month to ship) https://www.blackhawkjapan.com/produ...S&_ss=e&_v=1.0 |
#34 |
Drives: 2017 BRZ series.yellow
If you are burning up Hawk HP+ on the street, you are doing something very wrong.
That being said, it's an autocross pad, not a track pad. They have been excellent autocross pads for me. No fade ever, even at the big event I go to with 90+ second laps and 80mph top speeds. But having a factory PP car helps I'm sure. |
#35 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
What is initial bite like on the HP+ and MX72+?
Im looking for a new street pad that has a hard initial bite like Winmax W3 or Project Mu HC800 |
#36 |
#37 | |
Drives: 2017 BRZ PP, 2004 WRX
I like the higher initial bite for the my WRX on the street that has notoriously soft pedal feel on the normal calipers. For my autocross BRZ, I prefer less initial bite and a more progressive feel... plus the Brembos don't need any more feel really. You end up adding too much brake a lot of times. Check out the Stoptechs if you can still find them. Not sure if they'll be in HP+ territory as those are more of a semi-track, kinda streetable pad IMO.
#38 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#39 | |
Actually think i may try Project Mu HC-CS next. Here are the specs and differences for me from RHD Japan (Note i have a 6 piston front kit): MX72 Plus: Material: Ceramic Carbon Metal Applicable Rotor Temperature (℃): 50~750 Friction Coefficient (μ): 0.39 ~ 0.47 (F) MX72 Plus AP Racing 6 Pot D51 - RCP116: CA$323.08 (R) MX72 Plus BRZ\86 - EP472MXPL : CA$168.23 PMu HC-CS: Material: Super Graphite Metallic Applicable Rotor Temperature (℃): 50~800 Friction Coefficient (μ): 0.41~0.50 (F) Project Mu Type HC-CS AP Racing 6 Pot D51 - F1093: CA$175.92 (R) Project Mu Type HC-CS - ZC6 ZN6 - R914_HC-CS: CA$147.78 I wanted to try the CSG CP: 0.43 - 0.49 μ 50 - 700 °C But the price for the stock brz is $360US per axle, which is CA$518 Canadian tire bucks each axle before shipping. |
#40 |
What the hell are you guys doing on the street that you need more aggressive pads?
I run have cheap low dust pads in everything from my 850hp suv to… pretty much all ny cars.
#41 | |
They’re in a bbk but I bet they could last something like 25 HPDE days.
#42 |
Anti stance.
I went CC-Rg just now to pair with the Essex Endurance kit front and stock rears.
I'm currently on PMU HC+ on factory front and rear, and if the Endless feel and handle like the PMU, I'll be ecstatic. I've been struggling to find the HC+ in the CP8350 D50 pad shape. |
| Not Another Brake Pads Thread 2022 Edition | SlowCarFast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 03-01-2022 03:19 PM |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 06:27 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
