Old 11-08-2024, 06:52 AM   #4467
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by MrSkubi View Post
Here's an odd one regarding KW V3 Clubsport Coilovers:
Is it normal that I'm often hearing hissing sound similiar to let's say bicycle fork operation from rear of the car with this style of coilovers when going through bumpstops ?
I wouldn't think so.... Might be worth getting the car on some jack stands and jacking up the rear suspension and look/listen for anything strange as you compress and uncompress the shock
autoracer86 is offline   Reply With Quote
Old 11-08-2024, 07:49 AM   #4468
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Funny enough I've been told by the EU dealer that the've had similiar issue with Clubsports for MX5 and after inspection at KW Germany apparently they got the coilovers back as working properly. Obviously I'll have them checked again but I kind of doubt that I'll find anything suspicious.
MrSkubi is offline   Reply With Quote
Old 11-12-2024, 10:19 AM   #4469
Tokay444
Anti stance.
Tokay444's Avatar
What does, "going through bumpstops" mean?
Old 11-22-2024, 07:45 AM   #4470
MrSkubi
MrSkubi's Avatar
My bad - I meant speed bumps. Edited original post already
Honestly I'm not sure what to do with it further on. All suspension component has been checked for proper torque as well coilovers which are set just like manufacturer supplied manual suggested. Car is lowered just 20mm.
It's literally a sound that you can hear while standing near speed bump and car passes through it but in my case it's very clearly hearable inside cabin even with rear seats up. I was just wondering if it's even unusual for KW V3 style coilover.
Old 01-26-2025, 11:54 AM   #4471
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I haven't heard any weird hissing from my RCE SS-1's that are essentially a KW body.
Did you ever figure out what this was?
cmiovino is offline   Reply With Quote
Old 02-06-2025, 01:32 AM   #4472
MrSkubi
MrSkubi's Avatar
Not really. Currently I'm still troubleshooting it with KW dealer and KW themselves. The dealer told me that It's not unusual for Clubsport (they had similiar "issue" with MX5 kit) while KW states that V3 Clubsport should not make noise like that. I'll most likely send them audio and video clips in a month or so when weather gets better in Poland because I'm not driving this car atm. I've had coilovers before and I'm no stranger to "coilover NVH and strange noises" but this is something else. It's a bummer for me because I was really expecting trouble free dual duty coilover set and this super loud strut operation is not acceptable for me at all. If I won't get it solved I moght just move along to other suspension. I'll update on this later on
Old 02-12-2025, 12:27 AM   #4473
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Does anyone know the shaft diameter for KW V3?
@Racecomp Engineering or @CSG Mike maybe?
Old 02-12-2025, 10:23 AM   #4474
22mm front 18mm rear.
- Andrew
Old 02-12-2025, 02:14 PM   #4475
CSG Mike
CSG Mike's Avatar
Andrew beat me to it!
Old 02-24-2025, 09:12 PM   #4476
Mr_Brian
Are pillowball front lower control arm bushings worth it? I'm going to freshen up the bushings on the front of my car and was wondering if anyone has any experience with these bushings. I'll be doing a lot of autocross this year which is why I was considering pillow balls.
Bushings==> https://hardraceusa.com/collections/...6-fr-s-1st-gen
Mr_Brian is offline   Reply With Quote
Old 02-25-2025, 09:54 PM   #4477
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Have you looked at your class to see if they're allowed?
Old 02-26-2025, 11:34 PM   #4478
cmiovino
cmiovino's Avatar
Double check the rules for your class. If you're in street class, replacing most bushings with anything aftermarket is a no-go. In street touring, you can use different materials like polyurethane, but stock location is required. Generally speaking, even using the bushings that came with something like the SPC rear control arms (a common upgrade) were illegal until just very recently due to the amount of metal vs bushing material. given that, I'd say pillowball are likely not legal for street touring... which bumps you up into the street prepared/modified areas.
Someone double check me though. I never see pillowball bushings on any STX (now DST) build list. If there was any advantage and if they were allowed, people would be running them.
Edit: Here you go...
Suspension bushings may be replaced with bushings of any materials
as long as they fit in the original location. Offset bushings may be
used. This does not authorize a change in type of bushing (e.g., ball
and socket replacing a cylindrical bushing) or use of a bushing with an
angled hole whose direction differs from that of the original bushing.
If the standard bushing accommodated multi-axis motion via compliance
of the component material(s), the replacement bushing may not
be changed to accommodate such motion via a change in bushing type,
for example to a spherical bearing or similar component involving internal
moving parts. Pins or keys may be used to prevent the rotation of
alternate bushings but may serve no other purpose than that of retaining
the bushing in the desired position.
Old 03-07-2025, 01:38 PM   #4479
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Spherical anything in the front LCA is not legal in most pro-solo classes.
That said, I have those exact bushing in my car now, and the ride was noticeably worse. Also thought I wasn’t worth it, until I took a corner.
The more the you load the front, the better it feels. With sticky tires they really make a difference in feel. Overall grip/performance - not so much.
BlueWhelan is offline   Reply With Quote
Old 03-11-2025, 03:55 AM   #4480
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
So uh... what's your go-to option for fixing the chassis threads that the bolts at the front of the rear subframe go up into? >.>
One side is beyond a thread chaser (I tried, and I made it worse). Quite possibly beyond a tap at this point, too. Other side might be re-tappable and I have one on the way to try.
I necro'd the thread about it, but figured I'd ask here to hopefully get some advice from a professional shop.
grippgoat is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
