Old 05-27-2020, 04:07 PM   #127
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Originally Posted by ShawnP19 View Post
For the love of everything holy please do not cut your dipstick tube! You're trying to bring oil level up to the dipstick, not lower the dipstick to the oil level! If you don't see it on your dipstick, you don't have enough oil and need to add more. @blackfireball5
Lol. I didn't plan on it. I couldn't understand why changing the lower oil pan would make that dudes dipstick read inaccurately.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 05-27-2020, 05:26 PM   #128
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Same concept as adding an oil cooler, for example, more volume to fill, so you need more...volume? lol you get it.
ShawnP19 is offline   Reply With Quote
Old 05-28-2020, 02:05 PM   #129
blackfireball5
I struggled to believe that person thought they could get away putting stock oil amounts in with a larger oil pan. ��
I have a turbo, an oil cooler, and will have the FBM pan. So i will have quite a bit more oil required. Lol
Wheelwell Profile
Old 11-26-2020, 06:29 PM   #130
86joe
Drives: 2013 Scion FRS
I can confirm that this pan is causing issues with oil backing up into the turbo due to not draining correctly. I filled my car with oil until it read dead center between the 2 dots on the dipstick, and when I removed the turbo drain line from the pan (to diagnose my excessive exhaust smoking and oil in the downpipe) over a quart came gushing out. The return hole on the pan, when the car is filled to satisfy the dipstick, is BELOW the oil line. The dipstick reading is no longer accurate with this pan when using the return port. I ran a supercharger for 4 years with this pan with no issues but that's because Rotrex superchargers dont use engine oil so I never had this problem.
86joe is offline   Reply With Quote
Old 01-13-2021, 05:37 PM   #131
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Pardon if this is asked and answered somewhere, but I haven't had and luck finding it..
Will this pan fit with Tomei EL header? The header sits fairly close to the pan, and looks like it might hit where this pan is larger than OEM..
pic from their website: https://www.tomeiusa.com/_2003web-ca...ku_equal_l.jpg
also, would some heat shielding between the header and pan be beneficial? the pan itself is designed to shed heat from the oil, but that doesn't help if it's being cooked by a header!
Matt93SE is offline   Reply With Quote
Old 09-16-2024, 12:19 PM   #132
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
What did you end up filling to? i had the same exact issue. thought that the turbo blew.
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
KxngCorey is offline   Reply With Quote
Old 08-12-2026, 09:19 AM   #133
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I know this is a necro post but in case anyone runs into this problem; the Full Blown Motorsport pan is awesome. High quality and great. However, the drain location can cause an issue on hard braking if you're using a front mounted turbo. The hard braking can cause the oil to push back up the drain line and cause the turbo to not fully drain properly.
The only real fix for this that I can see is to move to using a scavenge pump like this: https://avoturbo.com/brz-frs-86-repl...-oil-pump-kit/
RongTurnRacing is offline   Reply With Quote
FRS Die-cast model encity5 Scion FR-S / Toyota 86 GT86 General Forum 75 02-24-2019 01:15 PM
Expensive, but cool Die Cast GT-86 Kimsey47 Scion FR-S / Toyota 86 GT86 General Forum 25 11-26-2013 06:12 AM
FS: Die-cast EBBRO 1/43 frs 86 blanco Miscellaneous 4 09-25-2013 11:42 PM
Durability of cast wheels AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-06-2012 06:10 PM
Any Disney Cast Members here? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 9 11-18-2011 02:48 AM
