Old 08-10-2026, 08:03 PM   #19909
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Originally Posted by Grady View Post
I should have done this sooner.
The thanks button does not seem to work for me.
Nice Banana all color coordinated, I like that!
The Red One is offline   Reply With Quote
Old 08-10-2026, 08:34 PM   #19910
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I discovered something that made me not very happy.
RongTurnRacing is offline   Reply With Quote
Old 08-11-2026, 11:41 AM   #19911
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
I found something similar as well. While not quite as bad as yours, still concerning.
I put it on the subreddit and someone suggested to use powdered laundry detergent to flush....
I'm not going to try it, but I was intrigued
I feel like mine was caused by mixing different coolants. What do you think your issue be?
smackrel is offline   Reply With Quote
Old 08-11-2026, 02:07 PM   #19912
RongTurnRacing
Well, since it didn't smell like anything but coolant (no oil/petroleum smell), what I'm finding was that it's residue in the system. I use Water Wetter and everything I can find says that would potentially cause this. A mix of different coolants could also cause it.
I still have a little more inspection to do but it might be just fine. I'll do a pressure test to rule that out and do some other checks and I should be OK hopefully.
Old 08-17-2026, 08:47 AM   #19913
new2subaru
Weight Weenie
Drives: 15 FR-S
Wow, that looks nice! The whole package.
Old 09-08-2026, 06:21 PM   #19914
Kauf
Drives: 2014 SSM BRZ
Sew what? The upgrade is wheel.
Technically, I did this a couple years ago, but missed posting about it then. I got this off ali express for a pretty good price and am pretty happy with how it turned out. My OEM wheel was peeling in spots. It took a little time and it didn't fit perfectly (there's a little wrinkle on the back side I had to learn to live with), but other than that, I actually like the slightly thicker feel and actually think it's improved look and feel over the original.
I also recently installed the OEM STI Aero kit after looking at it for ... a long time. And changed the coolant myself for the first time. Not too bad and I love how the tube in the reservoir could double as the drain tube at the bottom.
Kauf is offline   Reply With Quote
Old 09-16-2026, 02:22 PM   #19915
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Where are the photos of the aero kit installed?
Living life on the edge, less crowded, better view!
2018 tS Still in the family.
Old 09-20-2026, 05:51 PM   #19916
Kauf
I posted them over in the SSM pictures thread and linked it in that text above. If the photo isn't showing for some reason, let me know.
