#127 | |
Drives: 2013 Subaru BRZ Turbo
Good luck with the build. It's just going to get better and better. |
#128 |
Drives: '13 FRS - STX
SPC lower control arms are not ST legal last I checked, they use a spherical bearing on the inboard side instead of elastomer.
https://www.spcalignment.com/product/67660 "Get the ultimate in performance and handling with this stamped arm featuring our new xAxis Sealed Joint which performs like a pillow joint but lasts like an OE joint." Cheap and easy (should be <$300) is the whiteline version that puts a polyurethane bushing in that spot. Although I've had issues with it slipping (pretty much entirely due to street driving) - haven't roughed them up yet in an attempt to get better bite, but that's all I can think of to fix them without spending $$$. https://whitelineperformance.com/us/...-kta216a.html? Seems like swapping the upper control arm is the latest hotness, but at >$600 I'm not excited about it, at least you can shed some weight and stiffen up those bushings in the process. |
#129 |
Drives: '22 BRZ
Cusco upper arms are ~$400 imported from Japan, wildly cheaper than the US distributor pricing and cheaper than the "good" lower arms that people spend a LOT of money on.
#130 |
Drives: 2018 Subaru BRZ
I rode in with Evan LeBlanc this past weekend and holy shit. I've sat with fast drivers, but Evan is different.
Also, I still hate 2nd gear on the 18 BRZ. Im thinking mimicking his setup which the main difference is he has an Equal Lenght Header and ECUTEk instead of OFT. The header was weird, part of the piping would stick up near the radiator fan.
#131 |
Drives: 2017 BRZ PP, 2004 WRX
It's a double edged sword depending on your lot size and course design. Our smaller lots love it. I like when you're just getting to limiter or maybe even well under it. Then when it's a wide open venue or course and you're having to go into 3rd or stuck on the limiter a while - eh, 100% with you. It sucks.
I'm on 245/40 vs 45. Might do 45 next year. We'll see. .... I should really get around to doing a header and tune. I was like 7th in raw out of 65 at the last event here locally and that extra power could have been a little bit more needed. Couldn't hurt, right?
#132 | |
#133 |
Is there anything else that I can do squeeze some extra HP out of the car?
Currently on, Drop in Air filter, Perrin Inlet, JDL UEL catted headers, OEM front Pipe, and ARK grip cat back with OFT Tune by Steve99. I was talking to Evan and hes on Grimmspeed Intake, P&L EL gutted cat header, HF Front Pipe and OEM exhaust, but on Ecutek.
#134 | |
| 2025 SCCA Time Trials Rules - General Discussion | RongTurnRacing | Tracking / Autocross / HPDE / Drifting | 13 | 01-26-2025 03:42 PM |
| SCCA T4 Build thread | rice_classic | Tracking / Autocross / HPDE / Drifting | 278 | 08-09-2023 01:29 PM |
| SCCA XSA thread | Breadman | Tracking / Autocross / HPDE / Drifting | 31 | 07-14-2023 06:42 PM |
| 2019 CDC & SCCA Autocross Thread | JakeRogue | Mid-Atlantic | 15 | 05-17-2019 10:58 AM |
| 2015 SCCA Solo Nationals Thread | Jawnathin | Tracking / Autocross / HPDE / Drifting | 140 | 09-15-2015 02:00 PM |
