Old 08-11-2012, 12:52 PM   #15
Dustin@Dynosty
Don is correct, the E85 is the only reason the fuel pump is inadequate at this horsepower level. Numbers people throw out are 30-40% increase in fuel needs when switching to E85 fuel.
We spoke to our Walbro rep on the pump and they were originally designing a pump for the vehicle but the bid went to Denso according to his notes. First part of next week we will pull the pump out and have some pics and more details.
Dustin@Dynosty is offline   Reply With Quote
Old 08-11-2012, 01:01 PM   #16
Don@Accelerated
Don@Accelerated's Avatar
Judging by your fuel use. Sounds like a 255lph to me.
Don@Accelerated is offline   Reply With Quote
Old 08-11-2012, 01:57 PM   #17
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I tuned my civ on e85 as of most recently. When we were breaking in the engine on the dyno I already had a 190lph pump with 440 injectors from my last setup (gas/NA build). I only made 210whp on my old setup. The new setup was making 240whp NA on e85 and really straining the 190lph pump. If I stuck with gas the pump would have been ok but because of the high compression I need to run e85. We were demanding too much from the pump at that point becaus of the 30% extra need on top over 93oct. 255lph solved the issue.
Anyhow, I wonder what ratin the stock pump is at?
TouchMyHonda is offline   Reply With Quote
Old 08-11-2012, 03:47 PM   #18
xwd
Here is an in-depth look at the fuel system from Deatschwerks:
http://forums.nasioc.com/forums/show....php?t=2391641
Old 08-12-2012, 03:23 PM   #19
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
speaking of deatchwerks...http://www.deatschwerks.com/products...tank-fuel-pump
i had started off with the walbro 255 and eventually ran into the issue where when i was on e85 with 900cc injectors i wasnt getting proper flow at the recommended 40psi so after research i found the deatchwerks 320. i recieved it and was very suprised! same size as the walbro and it was quieter! fuel issues went away and i had zero issues =)
and i would also highly recommend this from deatchwerks http://www.deatschwerks.com/products...stallation-kit
one could always make their own but as most technicians and tuners would know, its not always about fuel pressure you get but also the voltage the pump is getting. its amazing to note how much as little as 1V drop at the pump how many cc you loose and if you could get battery voltage to the pump, then that would help a lot too. i did a voltage drop test on my tC before i bought this kit and i would measure 12.8 volts at the battery but when i measured at the pump i only saw 11.9 volts
mastertech86 is offline   Reply With Quote
Old 08-12-2012, 10:22 PM   #20
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
why not a stealth340 or walbro 400? give it some headroom!
btw, Dustin, great to see you guys on this forum! this is "fawker" from mr2oc. one of these days i'll try to make it down and swing by the shop.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 08-12-2012, 10:37 PM   #21
Visconti
Drives: 05 STi
FYI DW pump sucks...
I used them when they first came out.
I'd use any Chinese knock off before using those pumps again.
John
Visconti is offline   Reply With Quote
Old 08-13-2012, 05:11 AM   #22
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Like most others, I have been extremely pleased with DW products - especially in Subaru vehicles. The 300 lph pumps are silent and ultra reliable. Used dozens of them
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-13-2012, 04:01 PM   #23
Dustin@Dynosty
Pulled the hanger out today, playing with fuel pump options. Talked with DW, they do not have a pump that will drop in, but are talking about it as well. We will update later on when we disassemble the hanger and see what we can get to fit. We stock the full Walbro line, DW and Aeromotive so we have plenty of options.
Old 08-15-2012, 01:45 PM   #24
dunphyjp
dunphyjp's Avatar
Drives: Ultramarine FR-S
now does anyone know if the Direct injectors and port injectors work off the same pump or are there two pumps individually in the tank for each set?
dunphyjp is offline   Reply With Quote
Old 08-15-2012, 01:48 PM   #25
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The DI pump is located in the engine bay.
Old 08-15-2012, 05:15 PM   #26
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Clutch and fuel pump should't be a big deal. Might as well do the flywheel while you're at it. Did I miss you say anything about the injectors? I would assume they're fine at that rate but I know nothing about DI.
GenkiElite is offline   Reply With Quote
Old 08-15-2012, 05:18 PM   #27
Dustin@Dynosty
IIRC, the main fuel pump in tank feeds the low pressure rail (which is the one we see dropping pressure) and the mechanical fuel pump in the engine bay which then cranks the pressure through the direct injection rail (which is not dropping) IIRC it is under the black protective bracket on the driver side intake bank.
Old 08-15-2012, 05:19 PM   #28
Dustin@Dynosty
yes factory injectors would be maxed with E85, i don't recall off hand at what figure we calculated but very limited use
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-22-2012 12:39 AM
