Old 08-19-2012, 04:12 AM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Will this fit? (width, offset and tire size Qs)
OK guys, I have been getting a LOT of PMs from people asking if certain combinations will fit. I just assemble this information from all of the other topics on this site, so this topic is going to be only for asking if a certain wheel dimension/offset or tire size should fit and the experts can help answer.
Start at the Wheel Directory and read up on what other people have already done:
http://www.ft86club.com/forums/showthread.php?t=7535
Make sure that you post ALL of the pertinent information in your question so that the answer can be posted without a lot of back and forth. Please specify the wheel size, width, offset, complete tire size and the amount your car is lowered.
Old 08-19-2012, 04:12 AM   #2
DarrenDriven
NW Region Moderator
This gets it started...
Originally Posted by jinrawke
I'd like to thank you for all your work gathering wheel information and have a quick question just to verify my math / logic is correct. So lets say I'm looking at 18x8 wheels at +32 offset. I see for the rear wheel, you have a silver star for the rear so I assume that +32 will come very close to flush which is a good thing. As far as the front I see you have a smiley face at +35.
So at stock height, that would mean the fronts would be sticking out by 3 mm?
You also mention that we would need to adjust the offsets when lowering the car.
Front - lowered 36mm (1.417 inch)
Rear - lowered 32mm (1.259 inch)
so conservatively I would need to be over +37 for the front and +38 for the rear?
Thanks for any help!
Old 08-19-2012, 04:24 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm here to help also guys better to ask than end up with less than ideal fitment.
Old 08-19-2012, 04:25 AM   #4
DarrenDriven
NW Region Moderator
@jinrawke - An 18x8.0 +32 will be 6mm sunken at stock height since a +38 is flush. If the car is lowered 1" then the camber will cause the top of the wheel to sink another 2mm, so you would end up 8mm sunk at the top of the wheel. Not too bad... that is about 5/16" sunken and would look fine.
At the rear at stock height an 18x8 +32 will be flush. If you plan to lower your car 1" then you will sink the tops of the wheels 5mm... which would still look totally fine.
A smiley face is a link to a topic where someone on the site has actually installed that wheel spec... and a star represents perfect flush AT STOCK HEIGHT.
Old 08-19-2012, 06:39 AM   #5
helloimgil
helloimgil's Avatar
Drives: 13 Whiteout / 09 R6 [BRZ is gone!]
Thanks!!
helloimgil is offline   Reply With Quote
Old 08-19-2012, 07:53 PM   #6
JoeBoxer
JoeBoxer's Avatar
+32 would be 6mm poke if +38 is flush, not 6mm sunken.
Old 08-19-2012, 08:23 PM   #7
lucchesi423
lucchesi423's Avatar
Drives: 1991 MR2 turbo, 2013 Scion FRS
this ^
lucchesi423 is offline   Reply With Quote
Old 08-19-2012, 10:05 PM   #8
JoeBoxer
JoeBoxer's Avatar
You might be getting too technical trying to add the camber in too as most people on spring drops won't be able to adjust it anyways. My best tool is the offset calculator on 1010tires.com I think it gives the best idea we can get without actually test fitting.
Old 08-19-2012, 10:12 PM   #9
lucchesi423
agreed, my head hurts after that one lol
Old 08-19-2012, 10:23 PM   #10
lucchesi423
although i do think adding the camber into the equation will help people out down the road when it comes to more technical fitment.
Old 08-19-2012, 10:35 PM   #11
Suffa
Drives: Black GTS
Awesome thread, i always wanted to ask about my choice but didnt want to start yet another thread.
Ive been looking at some enkei SR6 & EV5 and they have 2 choices of offset. Ill be dropping on springs 1" when i get the wheels and using the stock rubber. What is the best offset choice?
SR6 = 17x7.5 offset available (40,50)
EV5 = 17x7 offset available (38,45)
Suffa is offline   Reply With Quote
Old 08-19-2012, 10:40 PM   #12
JoeBoxer
JoeBoxer's Avatar
lower number on either one. 7.5 +40 would be my choice out of those.
Old 08-20-2012, 05:47 PM   #13
helloimgil
helloimgil's Avatar
Here are a few shots when we test fitted 18x8 +32 yesterday. I will add more shots when I get tires and then more when the RSR iShocks come in.
http://photobucket.com/brztestfit
Old 08-21-2012, 10:32 AM   #14
thelegaCy
Drives: cbs brz limited - RIP
Hey guys would 18x9.5 +34 fit all around? What size tires would be good? I'm trying not to go for too much stretch as the roads around me are bad and i would rash the crap out of these if I stretched them too much. I was thinking 18x9.5 +34 on 235.. would I need coilovers or would a mild drop (1 inch) with a rear camber kit be enough to fit these.. sorry for the detailed question lol
thelegaCy is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
