#337 |
#338 | |
Drives: 2018 Golf R
Parting out HERE
#339 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
I still have no bogging issues, Ive been meaning make a video if my tests just so you can see first hand how im testing it but yea, 1st gear roll @ 1000RPM its a smooth climb, given theres no torque in that range but it does not bog in anyway, reacts just how it should, I still really wonder what it is, I know 2forme was solved with a tune but how come not all of us have the issue. Wierd
#340 | |
, however now im missing 2 screws I hope they will send me when I send my rebate Monday, tho those bolts are easy to find.
#341 |
Drives: FRS :D
Only one screw has backed out on my lid the other have no moved at all. Right now I'm rocking 3 screws but they are held in there real good.
Out of the FRS game
#342 |
Drives: Hot Lava FR-S
Was it the bottom-right screw by chance? That one backed out on me but all the other ones are in there strong.
Sent using mobile Tapatalk App |
#343 |
I had minor issues the first day I drove mine, then those went away. However, I noticed earlier this week that I have a hard fuel cut [assumed] at WOT.
So... now the diagnosing begins. |
#344 |
#345 | |
AutoX-10/10ths every run
#346 |
Drives: 2013 Scion FR-S-white out
#347 |
Drives: Whiteout 6MT FR-S; E30 BMW's
Also had one of the screws back out on mine. I reinstalled them with slightly larger washers. They don't seem to be backing off this time, but it took a month or so last time so time will tell.
For reference I'm using the black lid. Foam was applied at the time of install as the foam does not come pre-applied to one of the lids (which makes sense if you included the second lid as a customer choice for which they would like to use) |
#348 |
Drives: 2013 Raven FR-S
I had a couple screws back out. There was nothing wrong with the screws, seemed like a mistake during install on my part. My thoughts were it has to do with the foam seal being compressed/heated during use and/or sun. I figured it got softer and or more compressed when the other screws went in so there was less pressure against the plate. Which would have made it more susceptible to vibration. Either way, i went to home depot and spent $3 on some new screws and washers and havent had a problem since. Plus the stainless replacements match the aluminum much better anyways
.Edit Add: I don't think these issues are in any way bad for Airaid. I mean it's not like the parts are faulty, a bit of loctite, or more careful installation would have prevented the issues. It really says a lot when the company is so behind their product that they'll rush out parts to customers no questions asked. |
#349 |
Drives: 2015 Mustang EcoBoost
Had two screws rattle out on mine, so rocking it with only two screws for now until I can find some replacement screws.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
#350 | |
Drives: Firestorm FR-S
The issue I found was the foam seal, this broke and compressed around the screw holes and caused the lid to loosen up with the excess space. I'm assuming the engine heat and thin area around the screw hole is what made the foam deteriorate. I just finished a 1500 mile road trip and they are still good to go now after the re-tightening. |
| Official Hawaii Pictures Thread | touge-n00b | Hawaii | 172 | 08-24-2014 11:15 PM |
| AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information | AIRAID | Engine, Exhaust, Transmission | 396 | 10-04-2012 08:27 AM |
| Airaid Intake System Official GB - The pre-order | AJUSA.com | Engine, Exhaust, Bolt-Ons | 212 | 09-19-2012 07:36 PM |
| Does anyone have pictures of TRD intake | Pekingduck | Engine, Exhaust, Transmission | 2 | 04-26-2012 11:37 PM |
