#5321 | |
Kuruma Otaku
My thinking is just that the longer pipes' lengths (come to think of it, entire exhaust) need to be tuned to reach atmosphere between the firing of cylinders.
Because titanium. |
#5322 | |
Drives: '06 AM V8V Coupe
The minimum tube length needed will be that which lands the pulse between the primary pulse it "originated from" (was once in phase with) and the immediate next primary pulse. With a tube that can reflect the waves, you cut the required pipe length in half. At any rate, even a 1.5m long pipe is quite difficult to manage. Dream engine: 2 CBR600RR engines put together at the crank Hayabusa style. 15000rpm of V8 glory, 230 horsepower from 1.2 liters. Oh yea. Last edited by serialk11r; 09-09-2012 at 03:45 PM. |
#5323 | |
Kuruma Otaku
The thing is that the nature of the fabrication will create variables in the length and pressures in the runners so it may always have some out of sync waves to maje it sound smoother than a normal 4 cyl.
Because titanium. |
#5324 | |
WTF is in your car is not the same as "how did you fit a V8 into that thing?!"
#5325 | |
Kuruma Otaku
Cadillac Northstar engines (transverse mountings) have been crammed into Fieros...
Because titanium. |
#5326 | |
That Guy
Drives: 2013 asphalt FRS MT
I have no issues passing my annual physical fittness test for the military, my heart rate isn't any different then when I biked 60-70 kms a day, and my blood pressure is actually lower now, typically about 115 over 75. I'm just built like a truck. I stopped lifting weights when I was ~13 when I could max out the leg press and the ab machine and do 5 sets of 10 reps on each. I could use some cardio but honestly it's not as bad you'd think. This might seem like an excuse, but whatever. As a stoker in the Navy, working in temperatures as high as 65 deg C, there's typically two body flavors that can hack it, marthone runner types whose bodies can handle the dyhydration and guys like me that just store enough water. The biggest problem is that guys like me aren't in vogue anymore. Skinny metrosexual type guys are. Well, that and I would look rediculous on a sport bike.
#5327 | |
Dream V8 (added in previous edit) would be 2 CBR600RR motors put together. 230hp of 15000rpm glory. Probably lighter than a 1ZZ too lol. Actually a CBR600RR on its own sounds really good already at 15000rpm. Pretty sure I heard a sport bike screaming at well over 12000rpm yesterday, it was more glorious than the Lambos I've heard shrieking around town, imo. I wonder what Mazda is going to do with their Skyactiv lineup. The 6 speed gearboxes look promising, but the strokes don't look very high rpm friendly so far. |
#5328 | |
That Guy
#5329 |
#5330 | |
Kuruma Otaku
Or what about the 60° Yamaha transverse V8 that ended up in the second gen Ford Taurus SHO? 3.4L 235(?) Hp. That would probably fit easily, and cost 5% of the bike V8 idea... Heh. Edit: http://vancouver.en.craigslist.ca/rc...216585451.html
Because titanium. Last edited by Dimman; 09-09-2012 at 04:45 PM. Reason: link |
#5331 |
Nah, I'm not serious about that dream, it's just a dream :P Maybe someday, although I think I'd rather have a slightly lower bore/stroke ratio for low end efficiency (don't want crazy heat rejection, I can just buy a rotary for that :P).
Now that my concept of "high rpm" has been changed significantly (lol), I'm wondering what I can do with a Mazda Skyactiv-G 1.3L...only problem is this motor is wayy undersquare. Stroke alone isn't too horrible, 82mm is shorter than an F20C. |
#5332 |
Whoa, I just noticed that there's a limited edition GRMN iQ supercharged (probably not for the US)!
That would actually be a perfect starting point for this build. Seeing how Honda L15s are about the same bore and poop out at around 140hp, my guess is that the 1NR can take 9000+rpm before the heads are maxed out, maybe a little head work can get it up past 10000. 80.5mm stroke should be easy to work with too. I suspect the rods are nice and long as well. 10,500rpm limit with 10,000rpm power peak at 133Nm (lets say a rather mild NA build) is 140kW or just under 188hp. If that's possible, I'm not even sure I'd want to S/C it! But for fun, 25% boost on that would be 175kW~=235hp. Altogether for about the same service weight as 1ZZ hopefully. That would be freaking awesome. Last edited by serialk11r; 09-09-2012 at 05:57 PM. |
#5333 |
Site Moderator
Drives: ichi 86 Project
yeah it was internet order only
#5334 |
Still Dreamin'
Drives: 2001 Chevrolet Tahoe
Just worked out at the neighborhood track, the only other person there was a old man walking laps in a long flowered dress. Disturbing... it doesn't help that he drives a PT Cruiser.
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-22-2014 12:46 AM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 03:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 10:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 08:59 PM |
