#99 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Ordered two because one of the fellow Perth members is after one so decided to put two in the same airbag(they are small).
@86drift: no probs! I like supporting vendors who are on the ball. My latest purchase took LESS than 30mins.. AFTER hours. Very happy with that. Last edited by stevo_12v; 10-09-2012 at 09:33 AM. Reason: typo |
#100 |
These arrived today. Will install them tonight..
![]() ![]() ![]() EDIT: Picked up a hydraulic jack from MALZ Lift range: Lowered: 127mm Lifted: 420mm
#101 |
Drives: Ordered Pearl White GT 86 Manual
how is the avo intake going? car feeling any better?
#102 |
KDT Install :/
AVO intake is pretty good. The car feels a bit more responsive.
(I didn't use their AVO air filter, I'm using my TRD one - so I guess its really difficult to tell that much of a performance improvement) I tried installing my WhiteLine goodies last night. Spent an hour and a half mucking about underneath the car trying to figure out how the heck they installed the items(from their provided instructions). They say that the gearbox needs to be propped up so you can remove the mount for the KDT926 install, but they make no mention of you having to remove one of the aero panels underneath. Same applies with the KDT922 bush inserts. Here is a diagram of what I mean. ![]() Also I think that part of the exhaust needs to be removed to install the KDT926 mount as part of the exhaust(near the exhaust hangar hook) is blocking the socket tool from being of any use. You could use a spanner to undo it but I didn't have the patience to do that at 1:30am in the morning. Edit: found a pic off the forums. Credit to MOTIV Concepts. I've red-dotted the nuts that are blocked by the exhaust
#103 |
Track and Cruise
Today was a pretty good day.
08:00-12:40 I was at a track event with the SilviaWA club. Then a cruise with the 86/BRZ WA Crew up Mundaring Weir, Araluen, Coogee Left cruise at 7:00pm and here back at work until 11:30pm most likely. Gotta find a way to pay for these mods ![]() Here's the rough time sheet ![]() Suprising that my first runs actually had better times. The stock 215's sure do like to slide around a bit, albeit most of the course was quite 'gravelly'(Silvia guys were mostly drifting instead of doing a time-attack :P ) |
#104 |
Needs more quiet..
Ordered this for the engine bay.
Remove the 'noise generator' into the cabin. ![]()
#105 |
Update: KDT922 Install
Installed the rear back bushings behind the rear wheels. Took me about an hour and a bit. Very fiddly to install the rear bolts back on. Will be doing the other two bushings in front of the rear wheel tonight. Will try to complete the KDT926 shifter bushing too. |
#106 |
Ordered 5mins ago..
#107 |
[I 86 I]
Drives: Toyota 86 GT
Most modified 86 in Perth for sure!
Really enjoying this build thread
Silver 86 GT 6MT
Tein Street Advance Coilovers Perrin Unresonated Cat-Back System WedsSport SA70 : Bronze 18x8 +42 To come - Work XT7 Bronze F=18x8.5 +38 / R=18x9.5 +38 |
#108 |
how much you want for the Avo filter
#109 |
$55.00 there's a post in the Aust Classifieds section.
#110 |
Vtec Jesus
i like this thread
#111 |
KDT926 finally installed!
Took half a day off, and went to finish off the rest of my Whiteline Install, namely the KDT926 Shifter bushing.. some pics..
![]() ![]() I wish I had a molnar hoist sometimes.. ![]() Mid-pipe MUST be removed to install this. ![]() Much easier to remove the cradle assembly with the mid-pipe removed ![]() You can see the OEM rear shifter bushing behind the driveshaft. I wish I the Perrin rear shifter bushing I ordered had arrived. I will need to repeat this install again :/ ![]() Finally removed. This is mainly made out of rubber. You can easily move it around without much force. A lot of 'slop' ![]() Lubed up and ready to go. ![]() Quite an easy install, once it's lubed up. ![]() Yay! finally at last it's installed.
#112 |
I was going to order one of these..(Sound Tube Delete)
![]() But then got an email about the price.. No thanks
| Tags |
| 36yroldvirginscar, keyboardwarrior, trd |
| Dumb idea to get auto tranny? | tinnyms3 | BRZ First-Gen (2012+) — General Topics | 85 | 06-22-2012 06:22 PM |
| After this last winter is RWD such a bad idea | Nate219BRZ | Great Lakes | 3 | 03-14-2012 06:03 PM |
| Any Idea of U.S. Pre-Order Numbers? | markemark24 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-21-2012 01:29 PM |
| I have a great idea! | ftw-86 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 07-24-2011 12:14 PM |
| Marketing Idea for the FT-86 | JDMluv | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-02-2011 06:29 AM |
