Old 10-14-2012, 08:52 PM   #1
fl_speed001
Drives: Whiteout FR-S
Whiteline rear subframe bushing install...
Getting ready to order the Whiteline shifter bushing and am seeing these rear subframe bushings as well. Seems a decent bang for buck upgrade for improved feel. Wondering about difficulty of install, would imagine rear subframe has to be at least unbolted to get these in place.
Short version, should I order the subframe bushings at the same time and save on the shipping or is install a really involved PITA?
fl_speed001 is offline   Reply With Quote
Old 10-14-2012, 09:03 PM   #2
JoeBoxer
JoeBoxer's Avatar
Shouldn't be too bad if you have a lift, probably take a couple hours.
Old 10-14-2012, 09:04 PM   #3
fl_speed001
No lift, but plenty of garage space and jack stands. No stranger to working on cars, just wondering what all is involved in this particular install.
Old 10-14-2012, 09:07 PM   #4
green_comet
green_comet's Avatar
Drives: Ford Focus ST
I ordered the Whiteline shifter and rear subframe bushings yesterday, thought I might as well order them both at the same time.
The shifter bushing looks simple to install, but I have no idea about the rear subframe bushings. It doesn't help that the install guide linked on Whiteline's site isn't working either.
green_comet is offline   Reply With Quote
Old 10-14-2012, 09:31 PM   #5
OrbitalEllipses
Drives: Attitude
I noticed their install page was down for that product. Tip: The rear suspension is VERY similar to that of the GH/GR Impreza. Here's the install sheet for the Impreza GH/GR rear subframe bushing inserts.
^From Vorshlag's thread on NASIOC; all you do is lower the subframe ~1". I imagine it's as simple as unbolting one side at a time while keeping the middle of the subframe somewhat supported.
Old 10-14-2012, 09:36 PM   #6
green_comet
I sent a technical request to Whiteline earlier, they have now fixed the install guide link.
Old 10-14-2012, 09:42 PM   #7
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Im going to look into this, theres too much movement in the rear subframe, wouldnt want to damage the body after time. Theres a video showing it on a KW thread.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 10-14-2012, 09:48 PM   #8
fl_speed001
Ok, install question asked and answered! Fantastic and definitely going to order both now. Anyone have them installed for some feedback yet?
Old 10-14-2012, 10:08 PM   #9
whataboutbob
AutoX-10/10ths every run
Thanks for this thread. I'm getting ready to put some whiteline stuff on my FR-S and was looking at these bushing on their website. Looks like a simple install.
Old 10-15-2012, 01:48 AM   #10
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Whiteline Positive Shift Kit DIY.
http://www.ft86club.com/forums/showthread.php?t=19782
That GIF has me interested in that subframe bushing....
F1point4 is offline   Reply With Quote
Old 10-15-2012, 04:17 AM   #11
OrbitalEllipses
Drives: Attitude
Whiteline has a YouTube video that shows how much deflection there is stock. The bushing is a cheap effective mod, I just hate greasing poly.
[ame="http://www.youtube.com/watch?v=IDfJ_zYFPcs"]BRZ / FT86 / FR-S Whiteline Subframe Lock Out Kit - YouTube[/ame]
Looking over Whiteline's instructions right now and their torque values are off from stock for the main frame bolts and front support bolts; manual specifies 107ft-lbs and 52 ft-lbs, versus Whiteline's 72ft-lbs and 16 ft-lbs. For the main frame bolts one could make the argument that the new bushings account for the difference in torque, but for the untouched front support bolts? Their e-brake bolts are the correct torque though. Just wondering over the discrepancies...not sure if there's been service manual corrections at this point either.
Old 10-15-2012, 09:27 AM   #12
gmookher
personally find the two larger diff mount bushes to be too soft...
Old 10-15-2012, 12:44 PM   #13
fl_speed001
I haven't driven enough to be sure but based on the Whiteline vids I would agree that the stick diff mount bushing allows quite a bit of movement. I am sure diff bushing inserts will be out soon, they were a popular mod on the S2000 as well and helped make for a much tighter driveline feel.
Old 10-15-2012, 01:18 PM   #14
benster
Drives: none yet
that's a crapload of movement for both sets of bushings. did not expect that from a sport car.... definitely gonna be on my to do list.
benster is offline   Reply With Quote
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 08:45 PM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 04:48 PM
