Because compromise ®
Drives: Red Herring
Any idea where these bushes go?
I had sent sent Superpro an email asking about these bushes. I asked "Do SPF3818 bushes go in the same location as SPF3907K bushes? Am I correct in saying that SPF3818 replaces OEM bushes while SPF3907K supplements OEM bushes?" but my only reply was a copy & paste from their website.
Crossmember Insert Enhancement Kit Subframe to Chassis Mount Bush Kit It is these 2nd bushes I am asking about. Cheers |
#2 |
Drives: 2013 BRZ SWP 6AT Ltd
Wouldn't they mount to the Subframe to Chassis points? There are four points to the subframe and eight new bushings.
So wouldn't you press out the OE rubber and insert these? |
#3 |
Drives: Legacy GT
The first are inserts that fill some of the voids, the second is a complete replacement. The bushings that fill the voids are much easier to install because you don't have to remove the rear diff and entire subframe and then figure out a way to get the stock ones out. Whiteline also makes the complete replacements (and inserts which probably don't fit), and Kartboy has a similar set of the inserts.
#4 |
Drives: Moped
The bushes go in the ground next to the other bushes...
#5 |
Drives: Red Herring
It's great when a company can't tell you about a product they are selling.
This is the reply from an email I received: "Regards to you email for the Subaru brz ,spf3907k is a cross member insert enhancement kit for the brz where the spf 3818k is for the sub frame to chassis mount kit" No help at all. |
#6 |
Drives: GTS 86 Galaxy Blue
Have a look at whitelines videos on Youtube. They have a video of those insert bushes. They just fill the voids in the factory bushes.
#7 |
Drives: Red Herring
#8 |
Drives: 2014 Toyota GT86
#9 |
shrubbery?
| Throwing around an idea | DrDuquette | BRZ First-Gen (2012+) — General Topics | 18 | 08-04-2012 09:27 AM |
| What do you think about this idea... | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-20-2012 04:26 PM |
| Marketing Idea for the FT-86 | JDMluv | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-02-2011 06:29 AM |
