Drives: fast
Reverse is kind of hard to get into
It feels like i have to put a lot of pressure and kind of force it into reverse. Anyone else?
#2 |
Drives: 2013 asphalt fr-s
Yes same here. I usually release the clutch then depress it again. Most of the time it becomes easier. Also I let it warm up.
#3 |
Either let the car roll a bit or let the clutch out in neutral (as @Asphaltfrs1 mentioned) , I'm pretty sure the reverse gear does not have a synchro. Either of the above should respectively rotate the input shaft or the gear stack, which helps to line up the dog teeth and thus, engagement.
#4 |
Drives: Scion FRS
Letting it warm a bit is about the only thing that really helps. I'm glad it's staying in the garage for winter. I will definitely change the fluid in the spring. This is one cold blooded tranny.
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
#5 |
Drives: '13 FR-S
Related to this, I just got my FR-S and the only complaint is 1st to 2nd, and 2nd to 3rd notchiness. I know others have complained about this, but just wondered if it goes away with break in. I have noticed rev matching helps, but I'm lazy and just want to shift (and I shift slowly). Other than that, can't wait to get to one thousand miles so I can let her scream.
Don Ivey
'13 FR-S (Hot Lava) |
#6 |
Drives: Fast
It's suppose to be notchy
#7 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
I have no issue with it. But I always give the car a few minutes to warm up when the engine/exhaust quiets down
#8 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
Mine shifts into every gear, including reverse, smooth as can be, just for contrast. I shift into reverse at least once per day to back out of the garage. Only fluid I have changed is the motor oil(To Mobile 1 0w-20) and have 4700+ miles.
My previous car was a 350z with 6-spd manual, which others complained about as well and I didn't, so I may just be used to a relatively touchy transmission or have a high tolerance.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
#9 | |
Drives: 2013 Boss 302 & 2013 FR-S
#10 |
Drives: 2013 Scion FR-S, M/T argento
Think there have been posts about this before in cold weather. Here in the Midwest it's been approaching freezing & reverse is just about impossible until the car warms up. I started putting it in reverse when I park in the garage and leaving it there when I start up in the morning. There may be a little more wear on the clutch this way, I don't know...
#11 |
Car is stored in a garage... Where I live it might reach 40 in there at the peak of winter.
#12 | |
Drives: Scion FRS
#13 |
Drives: fast
putting the clutch in and out dosn't seem to help, and letting it roll is rarely an option. i just have to force it in
#14 |
Imperfect
Drives: 2025 C8 Z06s and more!
Fortunately, slotting into reverse has not been an issue for myself.
Temperatures have dropped, and the overall notchiness is more present, but still not something for me to be bothered about. Solid feeling / performing transmission, thus far.
| What kind of computer to use? | skatery1989 | Engine, Exhaust, Transmission | 32 | 10-25-2012 03:45 PM |
| Rotiform BLQ Concave 3-pc | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 09-19-2012 02:23 PM |
| What kind of key we get in FRS? | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-20-2012 07:52 PM |
| What kind of car is this? | switchlanez | Other Vehicles & General Automotive Discussions | 11 | 05-20-2012 05:33 PM |
| I'm kind of afraid... | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 09-14-2010 02:53 AM |
