| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Hypnotic FRS Member
Drives: FR-S [Raven]
Adjusting Speedo to new tires ?
i was going to call the dealer on monday - but i did a small upgrade - that according to the tire-calculator changes the speedo by 1.5% -- so im wondering wouldnt the dealer be able to dial that back in easilly so that all the calculations on the computer and spedo are exact ? its not alot but wondering if anyone has done that ?
#2 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I'm not aware of anything the dealer can do to fix speedo error due to different sized tires from stock. 1.5% is a pretty tiny percentage anyways, you'll get almost that much difference going from a full tread new tire down to the wear indicators. Also, a lot of cars are off by a small percentage when new.
You can always check your actual speedo error with GPS, and just be aware of real vs indicated speed at various spots on the speedometer.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#3 | |
Hypnotic FRS Member
im thinking about this too much... this might be a non-issue the more i think about it. |
#4 |
Over the past few years I've had quite a few sets of non-stock sized tires on my cars that have been up to 4-5% larger or smaller diameter than stock. The only time it has been an issue for me is with tires that were larger diameter than stock, which meant that the speedometer showed a slower speed than I was actually going. Specifically on our Forester XT, the calculated error was 1.6%, but the actual error was closer to 3%, as I found out when I was pulled over for speeding for 12 mph over the limit, when I thought I was only going 10 mph over, which should have been safe. When I later checked the speedometer error with a standalone GPS unit (as well as a speedometer app on my Android phone), I discovered that the speedo error was greater than what it calculated out to be.
#5 | |
Drives: Skoda Yeti DSG diesel 4x4
If it's the same in the US you can add up to 5% on the tyre diameter without worrying but I agree, a GPS will prove the point. The electronic speedos can be recalibrated with an after market gizmo. |
#6 | |
Drives: Attitude
http://dccdpro.com/zcart/index.php?m...ea6683906157c9
It wasn't made for this application, but if you're that concerned about it I'd see what Jeff/Spiider/DCCDPro can do for you. Quote:
#7 | |
It was just right but I had to mark the speedo with liquid paper to save constant mental calcs on the move. Luckily no cops ever stopped me and saw that speedo. |
#8 |
Drives: Attitude
That would definitely be a situation where you'd want a device as such, lol. I'll drive by some radars and see how accurate the speedo is; it should be reading higher BUT closer to actual speed due to my slightly taller tires. I should have appended my previous statement with "when you stay within 3-5% of stock tire diameter."
#9 |
unless they sell the little pinion speedo gears at subaru? I dunno, sorta new to the brand myself
| Adjusting headlights | hansthegerman | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 09-09-2017 11:39 PM |
| Adjusting The Swing Length of the Door | 7thgear | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-13-2013 07:40 PM |
| Change dashboard/speedo lighting? | rhysmcinerney | DIY (Do-It-Yourself) Guides | 4 | 03-03-2013 12:35 AM |
| cruise control and speedo issue.. | tibsy92 | Issues | Warranty | Recalls / TSB | 1 | 10-10-2012 01:21 PM |
| Adjusting the Rearview Mirror | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 2 | 08-24-2012 11:45 AM |
