#142 | |
Site Moderator
Drives: Stuff
I plan to loop it (to eliminate the cooler) on track if everything else is going smoothly.Others have seen close to 300 degrees I believe in the south.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#143 |
I Love custom Turbo kits
Drives: Limited BRZ
At what Oil Temperature should I consider an oil cooler as necessary?
#144 |
Site Moderator
Drives: Stuff
I'd prefer to keep it down around 250-270.
-Dave
#145 |
Drives: Attitude
Does a higher viscosity oil get hotter, cooler, or no difference?
#146 |
Site Moderator
Drives: Stuff
I have no idea.
-Dave
#147 |
Site Moderator
Drives: Stuff
@robispec did you get to the track last weekend for some testing?
-Dave
#148 |
Drives: SWP BRZ
Maybe I'm missing something...but where did you end up mounting the oil temp sender? I see you got the oil pressure on the end of the galley at the head, but didn't see where you decided to move the temp sender once the sandwich plate was removed.
Thanks again. |
#149 |
Drives: Black frs project
ok logging still not working but at ACS in fontana the ECU would start pulling power at 200 degree farenheit.... with a SEVENTY degree ambient day(I went back to my stock cooling system to baseline the car) oil temps were in the 290-295 range no pressure readings but I have gone to a 5/30 oil
Putting the BIG SOLUTION back in to see how it works. |
#150 |
Site Moderator
Drives: Stuff
I think it was 87 on Saturday and a few degrees less yesterday. I hit 235 after the cooler max but normally 230. Not sure how that would compare to the oem sender's reading. It's likely higher than the pan would read but lower than the head oil temps of ourse. My guess is that I'm within my 250 range that I'm good with.
-Dave
#151 | |
#152 |
200 is water
#153 | |
Drives: Nevermorange FRS
Someone asked does thinner oil cool faster/better... Sort of.
Go here for answer: http://www.bobistheoilguy.com/motor-oil-105/ Quote:
Since you're also a Honda guy you might want to know that I'm looking at running a 12.5:1 B18C with big cams at 8500rpms for 6 hours in a 2100 CRX with a 25gallon fuel cell. Oh yeah.. with an oil cooler.
PRO86 | STL | LuckyDog
#154 | |
Site Moderator
Drives: Stuff
![]() And I've seen cooler temps in the pan due to air flow and oil volume. Depends on sensor location, etc. Sandwich plates often read hot because the block heats the sandwich plate itself.
-Dave
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 06:42 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 10:48 AM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 01:55 AM |
