| View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler | |||
| WITH Oil Cooler Spirited Street Driving < 195 F |
12 | 8.28% |
| WITH Oil Cooler Spirited Street Driving 195-215 F |
9 | 6.21% |
| WITH Oil Cooler Spirited Street Driving 215-230 F |
11 | 7.59% |
| WITH Oil Cooler Spirited Street Driving 230-245 F |
3 | 2.07% |
| WITH Oil Cooler Spirited Street Driving 245-260 F |
0 | 0% |
| WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) |
0 | 0% |
| With Oil Cooler Tracked 195-215 F |
5 | 3.45% |
| With Oil Cooler Tracked 215-230 F |
4 | 2.76% |
| With Oil Cooler Tracked 230-245 F |
7 | 4.83% |
| With Oil Cooler Tracked 245-260 F |
6 | 4.14% |
| With Oil Cooler Tracked 260-280 F |
2 | 1.38% |
| With Oil Cooler Tracked 280 + F |
0 | 0% |
| W/O Oil Cooler Spirited Street Driving < 195 F |
5 | 3.45% |
| W/O Oil Cooler Spirited Street Driving 195-215 F |
6 | 4.14% |
| W/O Oil Cooler Spirited Street Driving 215-230 F |
30 | 20.69% |
| W/O Oil Cooler Spirited Street Driving 230-245 F |
16 | 11.03% |
| W/O Oil Cooler Spirited Street Driving 245-260 F |
11 | 7.59% |
| W/O Oil Cooler Spirited Street Driving 260-280 F |
5 | 3.45% |
| W/O Oil Cooler Spirited Street Driving 280 + F |
0 | 0% |
| W/O Oil Cooler Tracked 215-230 F |
0 | 0% |
| W/O Oil Cooler Tracked 230-245 F |
2 | 1.38% |
| W/O Oil Cooler Tracked 245-260 F |
8 | 5.52% |
| W/O Oil Cooler Tracked 260-280 F |
24 | 16.55% |
| W/O Oil Cooler Tracked 280-290 F |
5 | 3.45% |
| W/O Oil Cooler Tracked 290 + F |
4 | 2.76% |
| Multiple Choice Poll. Voters: 145. You may not vote on this poll | |||
#29 |
Site Moderator
Drives: Stuff
After the cooler.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#30 | |
Drives: GT86
Driving around with no load at 6k rpm isn't going to tell you much about oil system capacity, other than what it does in those conditions, which is of not much use to anyone. Your test of driving WOT up to 100mph or whatever will most likely put more heat into the engine than your extended part throttle testings. If you want to test the system properly, then you need to sit at WOT for extended periods of time. I think it's great that people want to do tests and show the results to the community, but please try and ensure they're actually worthwhile or it just ends up misleading people. |
#31 | |
Drives: Black frs project
no oil cooler went back to stock to see how bad it was. day was 75 degrees in the PM and the car SLOWED DOWN after it reached a certain temp... in the morning the car was doing 10 mph faster exiting turn 2 PS At the ACS "ROVAL" in Fontana CA you are at full throttle for 80% of your lap time and every lap you have a 40 second burst of WOT in the top three gears this was when I was seeing peak oil temps... The Z was the same way as the oil is used for the cam timing changes and this compresses the oil heating it up. Last edited by robispec; 02-28-2013 at 01:09 PM. |
#32 | |
I Love custom Turbo kits
Drives: Limited BRZ
If my WOT to 100 mph put more heat then the other test, why did the oil/coolant temperature stayed in check, but for the "track" test the oil temp rose like a b*tch? Last edited by Sportsguy83; 02-28-2013 at 05:13 AM. |
#33 |
Drives: Limited BRZ
#34 | |
Drives: GT86
Surely the question is more over do people need an oil cooler on track? If so then people who have driven their cars on track have already posted up numbers they've seen, however i've only seen one person post up figures that they've actually seen an oil pressure drop. Until more than one person does that then no, in my opinion, I don't think there is a need for an oil cooler. And for the record, I read your first post quite clearly. It does not state you alternated from 5-7k, it said you kept it over 6k, it didn't mention at what load level. To be technical about it, then yes any load on the engine including a static test is 'load', but it's not the type of load that's going to cause you oil temperature problems. Bear in mind how inefficient IC engines are. There's a lot of heat to be gotten rid of, and there's a huge difference between 30-40hp on a light static cruise than there is at 150hp+ consistently. Don't see this as an attack. It's critique and it's healthy to entertain it.
#35 |
yes 76 degrees
#36 | |
Drives: Limited BRZ
I agree the first post wasn't that specific. I respect your opinion and appreciate your input and YES, definitely this minimal test should NOT tell anyone "go get an oil cooler". I actually am in your camp. I need more data and info before buying one. My intent on doing this was specifically because there are vendors that say an Oil cooler is needed by everyone. IMHO before logging numbers, I didn't think it was necessary for a DD who drove spirited, liked to floor it often, etc. But, since I am not the oracle I wanted to see for myself what kind of numbers we were dealing with. I hope this post is just a first step to much more data and way better/more accurate tests to determine if a track car really needs it, including FI cars. :happy0180:
#37 |
Drives: GT86
As a wise engineer once told me, "Test, don't guess!"..
But he also told me "Never let the truth get in the way of a good story!".... which could apply to some vendors on here.. My day job is to provide solutions to a problem. Until I see a problem I won't try to solve it. I think that's where we are with the oil temperature thing. The simple solution is this. Fit an oil cooler and blank off air flow to it until you need it, e.g. a track day. |
#38 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Track day with me being no super star (just a beginner) with ambient temperature around 78F (26C) my oil temp topped out at 255F (124C).
A more spirited and accomplished track racer here in NZ topped their oil temp out at 284F (140C) in similar conditions - they're fitting an oil cooler! One of our club has installed the HKS oil cooler and on track it now tops out now at 212F (100C). I am likely to track about 5 or 6 times per year and am undecided on the oil cooler at this stage although I like the look of the Perrin one. Hope this temp info helps. .
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#39 |
Drives: Limited BRZ
#40 | |
Drives: a few
#41 |
Drives: Limited BRZ
#42 |
Drives: Silver Manual Toyota GT86
Did a training/trackday here in the UK on Feb 14th. Ambient was about 3 C (37 F) had to wait for the snow to melt a bit before we could start
Car is standard apart from a K&N air filter, with moderate track use (as fast as I as a beginner wanted to go) it peaked at 120 C (250 F) For pictures, torque screenshots, videos etc see http://www.gt86ownersclub.co.uk/foru...topic2412.html Bed and Breakfast car park the night before ![]() Screenshot from Torque, peak Oil Temp 120 C ![]() Normal daily driving sees it get up to between 90 - 100 C, a bit of a thrash on the road takes it up to 108-110 C Alec Last edited by keelerad; 02-28-2013 at 08:52 AM. |
| Tags |
| oil cooler |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 06:42 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-22-2013 12:36 AM |
| Oil Cooler Location? | Captain Snooze | Engine, Exhaust, Transmission | 5 | 11-26-2012 06:02 PM |
