#421 | |
P i N O Y P R i D E
Drives: 86 C7P MT
no. u gotta ask for a request before they attempt to redeliver. or u can pick it up from ur nearest local post office.
#422 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Im confused on how to tap the parking light wire with nigel harness
I dont wanna use a switch. I want them on when parking lights are on. How can i do this?
#423 |
#424 | |
Love Boost!!!!!!!!
I do have to run the black wire (one that goes to the switch) inside. But if i dont wanna use a switch Why tap to the tail light? Can i tap them to my day time running light so they come on when i lower my ebrake.
#425 | |
Sent from my SPH-L900 using Tapatalk 2 |
#426 |
Love Boost!!!!!!!!
I still dont know what wire i have to use to tap pn mu side markers
#427 |
P i N O Y P R i D E
Drives: 86 C7P MT
Im not sure about this. But i think the black wire that goes inside to connect into switch that it came with the harness. Tap that black wite to the white wire in the side marker.
#428 |
Drives: 2013 BRZ Limited - WRB, MT
from what i understand, the relay is red to battery, black to any ground. The switch is red to a power source of your choice and again black to ground. The red switch wire could go directly to the side markers or you could tap the fuse for the side markers or you could tap the fuse for the tail lights. You could then just leave the switch in the "on" position and stash it somewhere which is what i'll probably do unless it's easy enough to get it mounted. This will allow the fogs to always be on when you turn your headlights on.
#429 |
Love Boost!!!!!!!!
You think that will work?
#430 |
P i N O Y P R i D E
Drives: 86 C7P MT
Yes. Coz thats what i did to test the fogs. Before putting the wire thru the firewall and to the switch.
#431 |
Drives: Scion Fr-s
#432 | |
Drives: 2013 Asphalt Scion FR-S
Note: If you look at any circuit where power is connected directly to the battery(relay of harness for example), it will have a fuse. This is to protect the electrical device and your circuitry so you dont fry your system if a surge or spike, etc.. goes through. |
#433 |
#434 |
Drives: 2013 Whiteout FRS
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 09:38 PM |
| FINALLY - Got my FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-03-2012 06:16 PM |
| FINALLY GOT IT! | Ayaz2589 | NY / NJ / CT / PA | 8 | 07-28-2012 03:52 AM |
| Finally got it!! | percyng | CANADA | 21 | 06-17-2012 02:50 AM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 08:29 PM |
