Old 03-18-2013, 02:18 AM   #575
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Originally Posted by outlaw121 View Post
I need help with where to wire the switch power side inside the car
Sent from my HTC VLE_U using Tapatalk 2
Me too can anyone help or answer this?
mdf4uk is offline   Reply With Quote
Old 03-18-2013, 02:33 AM   #576
outlaw121
outlaw121's Avatar
Drives: 2013 scion frs blue
Are you using the harness from nigel Jdm? It's like super short I'm going to end up rewiring mine
outlaw121 is offline   Reply With Quote
Old 03-18-2013, 03:26 AM   #577
mdf4uk
Yes, i extended the white wire and mounted the switch on bottom of the panel under the steering wheel facing the floor but i am looking for a power source for the red wire to the switch that only works with the key on so i don't drain the battery accidentally by leaving the fog light switch on. thinking about this for power http://www.ebay.com/itm/ATM-Mini-Fus...286#vi-content
Old 03-18-2013, 03:55 AM   #578
outlaw121
outlaw121's Avatar
Do your lights work right now?
Old 03-18-2013, 04:23 AM   #579
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Originally Posted by calis5nest View Post
Where did you guys tap the positive switch wire to?
Igniton key or parking lights.
I'll take and post some pics this morning. sorry for the delay for the pics, its been busy week for me.
but before that u need this for safe and cleaner splicing
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-18-2013, 04:29 AM   #580
outlaw121
outlaw121's Avatar
Thank you!
Old 03-18-2013, 10:01 PM   #581
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Sorry for the delay guys. for those interested to tap their switch on ignition key.without draining the battery and u can turn on the fogs without turining on parking lights and headlights.
unplugged that white socket
remove the black cover insulator around these wires, and pull the green wire, with the splicing wire connector, connect the red wire from the switch to the green wire.
Note: U need to squeesh in very hard to get the perfect contact on the wire, coz the green wire has a thick insulator.
Then plugged it back in the white socket, then screw in here the ground wire
enjoy with ur working foglights lol. hope this help guys.
Old 03-18-2013, 11:28 PM   #582
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Thanks a lot for the pics! @86_FRS this is very helpful
-Alan
calis5nest is offline   Reply With Quote
Old 03-18-2013, 11:28 PM   #583
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
These are crap... And if you're using a bunch of force to get through what you think is insulation, it's probably just damaging your wire.
I suggest http://www.backinblackgp.com/Tap_And_Splice.htm
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-18-2013, 11:51 PM   #584
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
No problem
Old 03-19-2013, 01:15 AM   #585
outlaw121
outlaw121's Avatar
Smile !!!
Thanks so much man they work now!!! just have to wait on beziels from nigel-jdm and im set!
Old 03-19-2013, 01:29 AM   #586
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
any idea if we can get the dash light on with this way too?
lbroskee is offline   Reply With Quote
Old 03-19-2013, 01:34 AM   #587
calis5nest
calis5nest's Avatar
I might be wrong but I think the only way to get that is by getting stalk
-Alan
Old 03-19-2013, 01:56 AM   #588
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Here's mine on BRZ fogs... so much better than the outback fogs IMO
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 06:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 03:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 02:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
