Old 03-23-2013, 01:20 PM   #995
getbent
Drives: 2013 FR-S Blue MT
With only 1/2 inch more diameter the 215/45R17 aren't going to be stretched any noticeable amount. I am running the OEM tires on 17x8 and they only look a tiny bit stretched.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 03-23-2013, 01:22 PM   #996
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I just purchased a set of Enkei, 17 X 7.5, GTC01's at Tire Discount. (see my wheels thread). I rely upon them to know what can and should be done. I am using the same OEM tires and was told that I can, when replacing the OEM tires then go to a larger tire size (width) if desired. Regarding wanting to stay stock, the Enkei wheels have the same + 48 offset.
BRZfan is offline   Reply With Quote
Old 03-23-2013, 02:12 PM   #997
nemesisdrift
Drives: 2013 LR Limited
The tires stretching does not affect the circumference of the tire. The belts in the tire don't stretch. It changes the diameter by life .4-1.3% for every inch stretches or something
nemesisdrift is offline   Reply With Quote
Old 03-23-2013, 04:46 PM   #998
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Originally Posted by eddieEndo View Post
i didnt ask if i should run square wheels vs staggered telling me to get square wheels is not relevant to my question, by square i meant not stretching the tires for either rim
Sorry if the rest of the world defines SQUARE tire setup differently than you decided to do in your head. Width, offset, ET, radius, diameter are also words that you don't get to make up definitions for either.
http://www.lmgtfy.com/?q=square+tire+setup
It means 4 sides, same size. LIKE A SQUARE.
What you are trying to ask is "What tires should I run on my 8.5 and 9.5 wheels with no stretch" which is what the guy above answered. Don't be a **** or you'll just get it returned.
Khyron686 is offline   Reply With Quote
Old 03-23-2013, 06:18 PM   #999
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Will 18x9.5 +40 fitted with 235/40 rub in the front? Ken Gushi's personal FR-S has this setup, I'm wondering what was involved to make it fit
HRTROB is offline   Reply With Quote
Old 03-23-2013, 06:44 PM   #1000
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Got a good laugh hahaha
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 03-23-2013, 09:22 PM   #1001
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Originally Posted by Slick View Post
Just a follow-up to my post from a few days ago, I tested fitted my wheels again this time on both front and rear. (18x9 +35)
To give you a visual of how much camber you gain with crash bolts on the front suspension, here are some before/after shots. I didn't actually use crash bolts, I just pulled the OEM upper bolt out enough that the larger shank was out.
First 2 pics are before, next 2 are after the camber bolt adjustment. Spring is compressed to stock height both times for proper reference.
End result is that it will fit with the crash bolt installed.
Lowering springs should add a bit more camber that will also help for clearance. (ProKit on the way)
Slick,
I too am looking at 18x9 with a offset of e35.
http://www.wheeldude.com/catalog/pro...oducts_id=6330
According to the fitament calculator this gives to a clearance of -4mm front and -11mm rear. I was going to use the H&R spacers in 3mm and 10mm to create a -1mm flush finished product. But looking at your pics, the 18x9 in e35 ends up with a ton of poke or am I just looking at it wrong? The calculator with my desired setup tells me that I should be perfectly flush.
Long story short, I have been back and forth on my wheel choices over and over and just when i think I have it figured out I see something that makes me change my mind...
Is it possible that the Wheels are stamped wrong or build wrong, or is this what I can expect from a 18x9 e35 wheel on my frs? HELP?!
Added Info: Im thinking 245/35/18s for tires and droping the car 1.4" with the H&R springs.
ilpad is offline   Reply With Quote
Old 03-23-2013, 10:25 PM   #1002
N8marsh
Drives: soon....
wouldn't circumference change if diameter changes though?
N8marsh is offline   Reply With Quote
Old 03-24-2013, 10:03 AM   #1003
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by ilpad View Post
Slick,
Hey ilpad,
When are you looking to buy your wheels?
I will have mine back with tires mounted in a few days, same size too 245/35R18 in a Conti Extreme Contact DW.
As for fitment, I was pretty surprised when I initially test-fitted the wheels, not so much because of the fitment calculator but because there seems to be many others running with this wheel width (both in 17 and 18") and a +35 offset.
The camber/crash bolt makes a difference and so will springs as well. The H&R's should give you more camber than the ProKit I am going with.
It's hard to judge where it will all end up, but I think I'll be okay which is why I ordered the 245s after the test-fitting.
Slick is offline   Reply With Quote
Old 03-24-2013, 01:36 PM   #1004
NorseLegend
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
How will these work; 18x9.5 +22 front, 18x10.5 +22 rear? I've seen a few close to it that have worked, I think there was one with a +24 and a +20 that fits, so I was curious. I'm planning on running a widebody and the Vortech supercharger, so they do have a bit more of an application than just show, but will I be running any negative camber? Or should it be fairly level? I may just end up going with the +24/+20 offsets.
Also, any suggestions on tires? I think a 265/35 on the front and a 285/35 on the rear would work?
NorseLegend is offline   Reply With Quote
Old 03-24-2013, 06:22 PM   #1005
giraffee
giraffee's Avatar
Drives: Slowly
Will this fit?
17x8.5 +42 front
17x8.5 +32 rear
235/40/17
Stock height but later lowering 1"
giraffee is offline   Reply With Quote
Old 03-24-2013, 06:33 PM   #1006
Slick
Slick's Avatar
You should have no issues making that fit.
Are you planning on running staggered wheels but square tires just so that the rears are flush?
If so, I highly recommend just buying 17x8.5" +42 for all four corners and adding spacers on the rear if necessary. At least this way you can still rotate your wheel/tires from front to rear to minimize wear.
Originally Posted by giraffee View Post
Will this fit?
17x8.5 +42 front
17x8.5 +32 rear
235/40/17
Old 03-24-2013, 06:49 PM   #1007
itdansharpe
itdansharpe's Avatar
That's a TON of poke. I think you'll clear the strut f/r, but the fender (stock) will be an issue once lowered. If you modify the fenders for a widebody you'll get more clearance.
Tire sizes are appropriate for those wheel widths.
Camber won't be effected until you start dropping. You want a little negative camber in the back... 1-2 degrees depending on use.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-24-2013, 06:55 PM   #1008
NorseLegend
Alright, thank you. I don't really have any plans to drop, but if I do, it'd probably be no more than .5 - 1 inch. Just as long as I clear it at stock height, all will be good. Thank you very much.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
