Old 03-28-2013, 02:57 PM   #29
suaveflooder
Originally Posted by vault View Post
yea took it out for a few days to see if it still clunks... and it does =S
Took the jack out and it still does on the drivers rear?
suaveflooder is offline   Reply With Quote
Old 03-30-2013, 06:58 PM   #30
suaveflooder
For those of you with this issue, mess with the foam piece that holds the jack and tow hook. My noise came back and got louder. Make sure it doesn't move easily. I pushed on that push pin that holds it down and messed with the positioning a little. The push pin went in a little more and the whole piece sat in much better with ZERO movement without actually pushing on it. My "clunk" is 100% gone. No clue why or what caused it but i was wrong before on the jack. If the noise comes back, I'm gluing the thing down.
Old 04-07-2013, 03:21 AM   #31
suaveflooder
Noise came back. Anyone have a solution for this? I pulled some of the stuff out of the trunk and the clunk was still there. Drivers side only as far as I can tell. I messed with the foam again and while it does move, there is no way its moving with the carpet and stuff on top.
This is frustrating.
Old 04-11-2013, 03:40 AM   #32
suaveflooder
@Gen @akustique @Cameronghanson @OrbitalEllipses @automatic
The clunk on my car is really bugging me and I'm trying to figure this out. It gets better the longer I drive and it's worse when it's cold. Also, it's only happens on a sharp drop like say a pot hole style drop or a quick upward force of the suspension. I can hit dips on the freeway with out a single bit of noise.
Anyway, has anyone found a solution to this? I was doing a little reading and just looked up rear suspension clunk and found out the the STI's are notorious for having this rear suspension clunk. I wish I knew more about our suspension, but I imagine it's pretty similar.
Here is what I found:
"As many of you are aware inverted struts can develop an annoying "clunk". The problem is apparently caused by a lack of grease being distributed from the strut chamber onto the damper body. This causes two coated (Teflon?) bushings to not receive proper lubrication resulting in wear and rear strut movement becoming noisy, clunky and rough. One symptom is that when the car is stopped and the rear end raises up a bit, it remains up until the car begins forward motion then the rear suspension allows the body to drop abruptly with an audible clunk.....most of us find this really annoying.
The cure is to somehow cause the inner sealed bushings to become greased. There are only two ways I know to do this.....1. Remove the entire strut assembly, disassemble, clean and repack with grease and reinstall, or, 2. Remove the rear struts, disassemble, drill and tap to install a grease fitting, clean, repack and reinstall. #2 is intended to keep you from having to repeat #1 and save your struts in the process by allowing you to either routinely add a dab of grease or add grease when and if the clunking returns."
I'm almost at 3000 miles and at that point I wanna have toyota check this. Any thoughts? Could we possibly be experiencing a similar issue?
Old 04-11-2013, 10:24 AM   #33
OrbitalEllipses
Drives: Attitude
My Koni inserts will be here today and I should start building them this weekend and have them on then car hopefully within the month. If I still have the noise I'd be shocked (pun intended). Were you able to isolate it to either the front or rear shocks? To me it seemed like it was the front making noise on compression...and while it made the noise in the cold, it was very intermittent; Sometimes in the 20s, it sometimes occurred in the 30s with no real pattern.
Old 04-11-2013, 11:49 AM   #34
suaveflooder
Mine is just the rear passenger. If this becomes anything like the issue the STI's are having I'm adding coilovers. I hope it doesn't come to that. It is more noticeable when the car has been sitting. It really does sound like a blown strut or a loose center bolt. Gonna head down to the dealer today. I changed my mind
Old 04-11-2013, 02:38 PM   #35
suaveflooder
Well, problem found. Blown strut. Go figure, right? So, the car is staying at the dealer for a couple days. Car has 2400 miles on the clock. Toyota rep is coming down from irvine to document, strut is already on its way. They said i should have it back tomorrow or saturday at the latest.
Old 04-11-2013, 04:06 PM   #36
Dezoris
Dezoris's Avatar
Attachment 33571
How did they determine this? Leak?
Old 04-11-2013, 04:46 PM   #37
suaveflooder
No idea. I just took it to toyota and told them that the rear driver side strut was making some noise. I said that I doubt it was blown, but maybe the top nut loosened a little. I waited for about an hour or so and then the service guy came in and told me that he needed to keep the car and that the strut was blown.
The car is a DD and most of the roads I go on are REALLY smooth. Having had a super low car as my last DD, I still tend to avoid the rough roads. Odd, but at least it's under warranty
Old 04-11-2013, 05:15 PM   #38
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
I will be interested to see of this really fixes the issue. I have the same rear passenger clunk but I am on coilovers. I don't have it now since I am in Florida and the weather has been much warmer. Last month before it warmed up I had the clunk just about every morning on the way to work.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Old 04-11-2013, 05:39 PM   #39
Dezoris
Dezoris's Avatar
I have some wacky clunks from the rear as well, took the foam with tools out and still have it. Gonna go through and re-tq all the suspension tomorrow night.
Please post back after you get the car back.
Old 04-11-2013, 06:55 PM   #40
suaveflooder
Absolutely! I should have it back in the next couple days
Old 04-12-2013, 11:13 AM   #41
automatic
Drives: WRB BRZ
Interesting.
Maybe I'll have mine checked out as well. Could it be a coincidence that we all have blown shocks on the drivers rear? The rear shocks on the left and right are the same I think....if that was the case I would think 50% of us will have it on the left and the other on the right.
automatic is offline   Reply With Quote
Old 04-12-2013, 12:45 PM   #42
suaveflooder
Originally Posted by automatic View Post
Interesting.
I agree. I have read a couple people who said it was on the right so it might be right at that 50/50 mark. Either way, it doesn't seem to be common....which is a good thing
Rear end clunk when shifting? HuntingtonFRS Issues | Warranty | Recalls / TSB 26 10-01-2024 12:10 AM
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
Potential design flaw with factory rear suspension? (WATER in boot area) WTF Suspension | Chassis | Brakes -- Sponsored by 949 Racing 243 07-26-2018 04:06 PM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 06:49 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 01:10 AM
