Old 04-14-2013, 02:44 AM   #1
Frsexxxy
Drives: White Virgin frs
Will the ecutek stg 2 not do much with an injen intake?
Somebody told me it wouldn't do much since the short ram injen intake will confuse the maf sensor. I wanted to get the stage 2 since I already got my overripe, mid pipe, second cat delete, catback exhaust, and injen short ram intake. Should I even pay 800 for something that won't do much then?
Frsexxxy is offline   Reply With Quote
Old 04-14-2013, 02:45 AM   #2
thebear21
thebear21's Avatar
Drives: scion fr-s (RIP)
Visconti will do a custom map for you with the different intake. Ming "bogged" a lot on early throttle but he fixed it
thebear21 is offline   Reply With Quote
Old 04-14-2013, 02:48 AM   #3
Frsexxxy
What intake do you have?
Old 04-14-2013, 09:40 AM   #4
wparsons
wparsons's Avatar
It doesn't matter what intake you end up with, if the tuner will adjust your tune it will be done via data logs from your car so it's more of a custom tune instead of an off the shelf tune.
flickr
Old 04-14-2013, 09:59 AM   #5
2forme
A tune is almost a must for intakes, if only for safety.
Intakes like Injen rely on tricking the maf into running leaner to get more power. A tune will make sure the AFR is safe in the long run, which is a risk with using the intake on a stock tune.
Old 04-14-2013, 03:56 PM   #6
jflogerzi
jflogerzi's Avatar
Correct. Listen to these people. If you get an intake(which in mind is a waste now) get a tune.
Old 04-18-2013, 03:27 AM   #7
thebear21
thebear21's Avatar
injen short ram
Old 04-22-2013, 11:25 AM   #8
Frsexxxy
Can you show me how to do it for the injen intake? I just ordered my ecu, should get here wens.
injen short ram
wtb injen intake hunter3232792 Engine, Exhaust, Bolt-Ons 6 01-10-2014 10:19 PM
Injen Intake seven Engine, Exhaust, Bolt-Ons 4 03-09-2013 02:40 AM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 12:22 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
