Old 05-16-2013, 03:05 PM   #1
tdoggy57
tdoggy57's Avatar
Drives: Asphalt Scion FR-S
Oil change on low cars?
Have any of you guys driving low on coils (mine are Eibach R1 all the way down) taken your car to Toyota dealerships for oil changes? Trying to figure out if I may have a problem when I go. Thanks!
tdoggy57 is offline   Reply With Quote
Old 05-16-2013, 03:28 PM   #2
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Shouldn't be a problem. They have blocks of wood or ramps if necessary. They can even jack it up slightly to get the arms underneath the car. The BRZ/FRS may be lowered a lot, but if a jack can get underneath Robispec's and our car (which happened to be lower than his at one point), it should be fine.
CounterSpace Garage is offline   Reply With Quote
Old 05-16-2013, 03:36 PM   #3
PradiG
Drives: Fr-s
i second this, i have to jack up one side, get the arms for the lift under, then jack up the other side lol but it can be done
PradiG is offline   Reply With Quote
Old 05-16-2013, 03:54 PM   #4
frslee
Just drive it
Drives: 13' FR-S
frslee is offline   Reply With Quote
Old 05-16-2013, 04:07 PM   #5
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
a jack cant fit underneath my car :[
SLICVIC is offline   Reply With Quote
Old 05-16-2013, 05:30 PM   #6
CounterSpace Garage
Get some 2x4s. The BRZ/FRS, even slammed, is not as low as a slammed S2000 UNLESS you are Stance:Nation. 2x4s + progressive ramps will get you there.
Old 05-16-2013, 05:42 PM   #7
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I wish i can fit a jack under my car
Old 05-16-2013, 05:46 PM   #8
raptor87
Drives: 2013 DGM BRZ Ltd
I have one of these, it is kind of hard to wheel around but works well.
[ame="http://www.amazon.com/Advanced-Design-Model-ATD-7325-Profile/dp/B000OUZVK0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1368737109&sr= 1-1&keywords=omega+jack"]Advanced Tool Design Model ATD-7325 2 Ton Extra Low Profile Tuner Jack : Amazon.com : Automotive[/ame]
raptor87 is offline   Reply With Quote
Old 05-16-2013, 07:34 PM   #9
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Quoted for truth. It's almost like the engineers KNEW that the car was going to be lowered - much more ground clearance than s2k, even when wheels look way more tucked.
GTM_Challenge is offline   Reply With Quote
Old 05-16-2013, 11:15 PM   #10
Xdragonxb0i
Drives: ex500r
get some 2x6 as said . there you should be high enough to fit a jack underneath
Xdragonxb0i is offline   Reply With Quote
Old 05-16-2013, 11:32 PM   #11
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I use this, plus I put a hockey puck in the center. You could also drive up a 1 1/2" x 8" for extra clearance.
http://www.harborfreight.com/automot...uty-68050.html
JimmyMac is offline   Reply With Quote
Old 05-16-2013, 11:46 PM   #12
wheelhaus
wheelhaus's Avatar
I picked up this same jack a few months ago specifically for the BRZ, found a coupon for $99. It even reaches all the way to the rear diff under the bumper and muffler can after the front has been raised and the factory side jack locations are on jack stands. If the car were slammed, it might not fit, but 2x4's or 2x6's would easily remedy that. Unfortunately it's damn heavy at 93lbs, so it might not be going to the track.
For doing oil changes, I also picked up a fumoto valve, so I only need to raise the car enough to get under it with my arm and a drain pan. The rest is done up top.
Old 05-16-2013, 11:58 PM   #13
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Do yourself a favor, and bring a drink of something for the tech doing it. Having to deal with racking a car as low as you say is going to piss him off. A little peace offering can really go a long way, especially if you plan on returning to the same dealership. It would definitely start building a good relationship with the guy fixing it, and could only benefit down the road if some sort of warranty job was a judgement type call.
LavosTRD is offline   Reply With Quote
Old 05-17-2013, 12:06 AM   #14
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
LOL i actually need 2 2x4s stacked on top of eachother under each wheel to get my jack under . so i guess i am stance nation.
My old car- http://www.stancenation.com/2012/09/...ed-subaru-sti/
the process to get a jack under there was even harder.
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 03:42 AM
First oil change....ever. Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 04-12-2013 04:50 PM
When should i do an oil change? Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 112 03-15-2013 02:25 PM
Oil Change 86 FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-18-2013 11:00 AM
When will you be doing your first oil change? pr086 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 12-10-2012 05:48 PM
