#71 | |
Drives: 2019 Mazda Miata RF
#72 |
FT86Club Official Vendor
Drives: Subarus
Alex told me P1 so I wasn't going to argue.
#73 |
#74 | |
Drives: 2013 DGM BRZ M/T
#75 |
Trackman
Drives: Raven Frs
#76 |
Drives: Subarus
Thanks Adam! Once I get back to Chicago, I'm going to start working on the paddle shifters some more. I'll keep you posted.
#77 |
Drives: Subarus
Out of curiosity, are there people out there that would want to try and bond and assemble the wings themselves to save money? It would be a price difference of about $800 or so.
#78 |
form follows function
Drives: RIP '13 BRZ
#79 |
Rugger Extraordinaire
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
I'll be in for the pylon tow hook mount wing. Probably next year, though, lol. Middle class problems.
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out 2003 Nissan Sentra SE-R Spec-V - Traded for next car 2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss. 1997 Mazda Miata - Current |
#80 |
Drives: Raven FR-S
#81 |
Drives: Sterling BRZ Ltd
Definetly like the idea of some assembly required to save money.
#82 |
Drives: Subarus
It's not too difficult but it is labor intensive. You need:
To sand the inner surface and the ribs to scuff them for a good bonding surface A good, clean flat surface to work on (granite kitchen counter would be perfect) Some 1/8" aluminum strips and clamps from a hardware store Epoxy would be supplied. I would also recommend wet sanding and clear coating the wing because we use prepreg so there is no UV resistant gel coat. The cure time to work with the wing is about 24 hrs, but it takes about a week for it to fully cure to a usable condition. Because it takes so long and there is so much labor involved, we can cut costs significantly if the end user is up to the task of assembly. The package would come with: 72" prepreg, autoclave formed carbon fiber skin 4 aluminum ribs 2 aluminum mounts 2 72" aluminum rods roll pins epoxy end plates standard, bottom mounted aluminum uprights (pylon) steel base plate fasteners You can also upgrade the aluminum ribs and uprights for Tegris ribs and aluminum rod for carbon fiber rods to further reduce weight and increase strength and stiffness as an additional option. We can also upgrade to a swan neck style as well as an additional option. I should have final numbers within a week but for the DIY'ers we're hoping to sell the kit for about $2000. A bit pricey, but it is the highest quality wing you can buy. This very same wing has been used to take wins in international GT racing series across the world. Also, you can make it fully your own, the length is modular, the upright type and distance is modular, even the build materials are modular. As always, everything is made and sourced in the USA so once we place the build order, it usually takes four weeks or less to receive.
#83 |
Definitely interested in the DIY version
#84 |
Drives: Attitude
Interested in a rear diffuser more than a wing. Plans on that? Another thread perhaps?
| An introduction to Hancha Group | Hancha Group | Announcements, Contests, Giveaways | 23 | 05-26-2013 12:56 PM |
| Hancha Rear Toe Link | Hancha Group | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-05-2013 09:18 PM |
| Hancha Rear Toe Link GROUP BUY | Hancha Group | Groupbuys | 3 | 03-30-2013 11:21 PM |
| PTUNING FR-S/BRZ DS-325 3" Single and Dual Cat-Back Exhaust System. Group Buy!! | Mrc@ptuning | Engine, Exhaust, Bolt-Ons | 35 | 12-10-2012 12:55 PM |
| Wing or no wing? (rear spoiler) | quik1987 | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 12-12-2011 07:11 PM |
