#127 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#128 |
Drives: Scion frs, Manual, Hot lava
Just replaced my manual transmission fluid with amsoil synthetic Manual Transmission & Transaxle Gear Lube 75W-90. Made sure my car was level, filled the tranny from the top of the car with a polyvinyl tube and funnel. One of the things I noticed was that I had to put about 0.4L more than what I took out. My kms were 31600 (manual says to replace at 32000km) and the old fluid looked horrible.
My shifts are now much smoother and the car just generally feels nicer to drive. Highly recommend replacing your fluid, even just to fill it up to the correct level. My tranny took 2.7L instead of 2.3L like the manual states. |
#129 |
Drives: Scion FRS
quick question..anyone looking at their AT transmission...did you notice anything about the gasket? mine has crack marks at every bolt lactation. am hoping they arent all the way across. I checked the fluid and its super clear and there is no evidence of leaks anywhere, i took a rag and went across the entire pan, it was dirty but didn't come across any wet/shiny spots to indicate that i had a leak.
but those marks do have me a bit worried. |
#130 |
Drives: Subaru BRZ Limited M/T
Doing my A/T fluid this wknd. Will let you know.
#131 |
Drives: JAWS
I do lots of city driving, don't really beat on my car but do drive spirited and occasional autox. I already switched to motul 300 in the tranny and diff at 7400 miles. I plan on changing the diff fluid every 15k and tranny every 30k as proactive maintenance. I figure it's easy and cheap enough.
#132 |
Drives: Yes
Put in Motul 300 last weekend at 16k miles. Didn't feel a difference... 4th gear still "crunches" in at high RPM's but doesn't feel like anything is getting damaged per se.
Still felt good to get that smelly factory stuff out of there though :p
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#133 |
not playing cards
#134 |
Drives: Scion FRS
Redundancy....OOooops!!! Lol
#135 |
Drives: Scion FRS
#136 |
Drives: 2013 BRZ GBS
Does anyone know the part numbers for the
+ Rear Differential Drain Crush Washer + Rear Differential Fill Crush Washer + 2 Crush Washers for the transmission ? |
#137 |
Becoming A Regular
Drives: 2013 Raven FRS
Just ordered my Motul Gear 300 fluid from No Limit Motorsport
#138 | ||
Becoming A Regular
Incase you missed it reading through the thread. |
#139 |
#140 |
Drives: 2013 Firestorm 6MT FR-S
subbed for future ref
| Tags |
| differential, diy, fluid, transmission |
| Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 03:23 PM |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 09:57 PM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 06:47 AM |
| FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-21-2012 12:33 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
