Old 06-19-2012, 11:06 PM   #1
flawedchemical
Drives: Silver 2013 FR-S
Transmission fluid swap?
Has anybody thought of doing this yet. My recent dealings with new cars have shown that factory fluid blows. I've put royal purple synchromax in my last 3 cars with great results. I think there is a little room for improvement in this great gearbox, but I don't want to screw up either. I've noticed a moderate notchiness at below 3k rpm and when not completely up to temperature. I realize this is common in a manual tranny but would like to slick things up if I could.
Just brainstorming...feel free to chime in.
flawedchemical is offline   Reply With Quote
Old 06-20-2012, 08:25 AM   #2
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
IMHO, RicerPurple is garbage that is only sold due target demographic marketing.
Use Amsoil gear lube and you'll probably never switch back to anything else. The main thing to note is what type of Gear Lube you need and get the correct stuff. Some are harsh on yellow metals and will deteriorate your synchros. I don't know the specifics of the FR-S trans at this moment or I'd suggest a specific one. But Amsoil makes really good fluids.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-20-2012, 10:21 AM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm going to let other people experiment first. My personal experience has been with Subaru transmission and I've found that the Subaru Extra-S is fantastic for daily-driving and occasional AutoX. But it doesn't hold up to heat all that well. I'm currently running Motul 300 in my RallyX car with much better results.
But I would be curious as to what the Miata and S2000 guys have found to work. The BRZ/FR-S transmission is same with just small tweaks.
Old 06-20-2012, 10:24 AM   #4
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
Like lord Taku said...
Me it goes like this
Motul/Redline
Amsoil
Castrol/mobil1/penzoil
Really make sure components won't be harmed due to detergents and added synthetics Most lubricants are made to manufacturers specs.
NeedsmoreCowbell is offline   Reply With Quote
Old 06-20-2012, 12:08 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Amsoil
Torco
Old GM SM was great. Ford has one that supposed to be great too.
Redline is ok, depends on the car.. it SUCKED in the S2K IMO, felt very notchy.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-20-2012, 05:00 PM   #6
flawedchemical
I've run the ford stuff and wasn't impressed at all...switched to royal purple and it was much better. It may not be the niche brand but I've had good luck. I've always wanted to try redline too but never have. And I hear good things about Amsoil. I'm not a brand loyal kind of guy, so whoever supports this car and gets some good reviews is who I will go with.
Old 06-20-2012, 05:08 PM   #7
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Taken from advice by friends at S2Ki, I've always used GM Synchromesh Friction Modified; worked perfectly in my RSX-S tranny, & I plan to use it for the FR-S once I put a few more miles on =D
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 06-20-2012, 05:34 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
The S2K tranny doesn't use yellow metal in its syncros? I'll have to dig for it, but I thought the cutaway of the BRZ transmission used brass syncros. If so, GM SM is bad for longevity.
Old 06-20-2012, 06:13 PM   #9
flawedchemical
So what all is good for brass parts?
Or better yet...what chemical or substance in these fluids is bad for the yellow stuff?
Old 06-20-2012, 06:15 PM   #10
Koji_Online
N7 Spectre
Smile
I found the following article that says most modern transmission oils are not harmful to yellow metals, given that they are GL-4 oils; I was trying to look up the GL number for GM SM Friction Modified, but can't track it down as of yet;
http://www.bobistheoilguy.com/forums...1231273&page=1
The following 2 links are personal accounts of the fluid; one for regular use, the second from S2Ki w/ track useage =D
http://honda-tech.com/showthread.php?t=2184992
http://www.s2ki.com/s2000/topic/1824...tion-modified/
I will continue to look into this; OP, but if you are considering to use this please note that Friction Modified is different from regular GM SM fluid; as noted in the personal accounts =D
Old 06-20-2012, 06:16 PM   #11
Koji_Online
N7 Spectre
Sulphur, but in my first link up there it gives a better explanation than that =P
Old 06-20-2012, 06:47 PM   #12
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
+1 Subaru extra-s. You will find that teams support it for track use, its even more livable for the street.
chulooz is offline   Reply With Quote
Old 06-20-2012, 07:45 PM   #13
getbent
Drives: 2013 FR-S Blue MT
I think the BRZ calls for a GL-3 fluid which is not even a current spec any longer. I would say that GL-4 is probably the best fit.
AWD Subarus use a GL-5 fluid, which is what is not particularly compatible with the soft metals. So I'm not so sure Subaru Extra-S will be the best solution for this particular transmission.
getbent is offline   Reply With Quote
Old 06-20-2012, 08:43 PM   #14
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Redline MT90.
On a side note I love all these threads that i used to read on NICO 10 years ago lol. It's starting all over again.
GenkiElite is offline   Reply With Quote
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 10:42 PM
HKS SEQUENTIAL TRANSMISSION for the 86 ESBjiujitsu Engine, Exhaust, Transmission 20 10-30-2012 06:28 AM
Transmission? Pplater AUSTRALIA 1 06-05-2012 08:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 01:48 PM
