#155 | |
Drives: point A to point C. Screw point B!
[quote=wsites;2245459]
#156 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'm not going widebody. I'm trying to keep the car as stock body as possible. I may do a lip, side-skirts, and rear spats to make the car appear lower but that might be the extent of exterior modifications next to the fender roll/pull.
#157 |
Drives: 2015 Series.Blue
Any updates on your progress?
#158 |
They're finishing up integrating the ProEFI. I'm hoping to drive it this weekend, but we'll see. The A/C system still needs to be installed as well.
#160 |
[ame="https://www.youtube.com/watch?v=T5TlX4h4p5o"]2JZ FRS - Start Up +mod list - YouTube[/ame]
#161 |
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
#162 | |
building life
Drives: Raven Black, 6MT
#163 |
building life
Under the drivers tire is my fuel return line. I stayed up late last night working on my fuel system. I kept trying to figure out the best way to retain the stock fuel lines but it simply adds too many fittings. The stock setup runs a 3/8'' line from the fuel pump assembly, Tees to two 3/8'' down the frame, then hooks up to the FA20. If I kept that, I would have to Tee down to a single -8/-10 to an inline filter, then Tee back out to two -6. That's just too many fittings (I'm running mostly Aeroquip, w/ Earl's and Fragola odds and ends). I ended up buying -8 AN feed which will split to dual -6 with a -6 return.
What size lines did you end up using ? |
#164 | |
#165 |
Got all my stuff from summitracing.com.
I ended up having to go with different fittings since the ones I mistakenly bought weren't PTFE fittings. All fixed now, though.
#166 | |
building life
thanks for that! gonna be doing my fuel system here shortly once everything is ordered in, trying to find the right parts so i dont make a fitting mistake lol |
#168 |
Unfortunately, no. Just take some measurements and make sure you grab PTFE compatible fittings. Sent from my iPhone using Tapatalk
| Tags |
| 2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| Mr and Mrs FR-S Build | jaydee_do_work | Member's Car Journals | 2 | 12-04-2013 10:51 AM |
| 86 BUILD, AUS | JS86JS | Member's Car Journals | 9 | 05-31-2013 09:59 AM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 05:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 04:40 PM |
