Old 06-10-2014, 11:37 PM   #1
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
My 2JZ Build - Last post w/ dyno (565whp/435wtq) updated 14 Apr 16
Decided to move the most up to date stuff to the front so you guys can have instant gratification.
Video link:
[ame="https://www.youtube.com/watch?v=T5TlX4h4p5o"]2JZ FRS - Start Up +mod list - YouTube[/ame]
https://www.facebook.com/trustautomo...type=2&theater
Mod list - Updated 18 Feb 15
2JZ-GTE / V160 Swap - 2JZ FRS
All custom fabrication, wiring and tuning done by Trust-Automotive in Chesapeake, VA
Engine - Built by Magnum Machine in Chesapeake, VA
  1. GSC S2 Cams
  2. GSC Beehive Springs/Ti Retainers
  3. GSC Valves (OEM size)
  4. GSC Valve Stem Seals
  5. Bowl work
  6. ARP L19 Studs
  7. CP 10:1 Pistons .020" over w/ upgraded pins
  8. Carrillo Rods
  9. ACL Race Bearings
  10. ProGram Billet Mains
  11. PHR Modified Timing Gear
  12. PHR Modified Oil Pump
  13. PHR Billet Aluminum Idler Pulley
  14. MVP Billet Tensioner Bracket
  15. Gates Timing Belt
  16. ATI Harmonic Damper
  17. Titan Cam Gears (Black)
  18. PHR Billet Aluminum Pulley Set (Black)
  19. PHR Oil Filter Union (possible change depending on temps)
  20. Custom Catch Can Setup
Turbo & Intercooler
  1. Precision Turbo 6466, SP Cover, divided 1.0 A/R - Black ceramic turbine housing/Polished compressor housing
  2. PHR S45 Manifold, black ceramic coated, dual wastegate
  3. Tial MVR Wastegates
  4. Tial Q BOV
  5. Custom Intercooler setup
  6. Custom 3'' Exhaust setup, single exit
  7. PHR Turbo feed line
  8. PHR Turbo drain line
Fuel System
  1. PHR -8 AN Fuel Rail - Black
  2. Injector Dynamics 2000cc injectors
  3. E85 compatible lines, fittings, sensor, filters
  4. FullBlown Motorsports E85 drop-in fuel pump - Walbro 400
Cooling System
  1. Custom Griffin radiator setup
  2. Dual 11in Electric fan setup w/ shroud
  3. Custom overflow (In Progress)
  4. Custom lines (In Progress)
  5. OEM A/C retained (In Progress)
Drivetrain
  1. Clutchmasters Induction Performance Spec FX850 Clutch
  2. IS300 M85 Differential - 3.73 FD
  3. Driveshaft Shop custom driveshaft
  4. OEM FT86 Axles (will be upgraded after break in)
  5. Custom Trans mount
  6. Transmission Tunnel plate steel reinforced
  7. PHR Billet Shifter Bushings
  8. Custom SS braided clutch line
Engine Management & Wiring
  1. ProEFI 128 w/ harness
  2. ProEFI sensors (AFR, MAP, AIT, Fuel Pressure, Boost, etc)
  3. CAN Color Display Logger
  4. CAN Cable
  5. ChaseBays custom dual-ECU wiring harness
  6. EcuTek
Wheels, Tires & Suspension
  1. Enkei RPF1 - 17x9 +45, 5x100
  2. Tires TBD - 275/40R17 rear, 245/45R17 fronts
  3. Alignment specs TBD
  4. KW V3 Coilovers
  5. SPL Rear LCA's
  6. RaceSeng CasCam Plates
  7. RaceSeng Rear Bump Stops
Interior
  1. OEM GT86 Black interior panels
  2. RaceSeng Slammer Knob
Exterior
  1. Valenti Smoke Tail Lights
  2. Valenti Fourth Brake Light
  3. Blacked Out Headlight Interior Housings
  4. Helix Side Markers
  5. DriftArmor Crash Bar
  6. Beatsonic Shark Fin Antenna
Parts Unused Currently:
PHR Oil Filter Relocation Kit
Current state
  1. Transmission mounted
  2. Radiator Mounted
  3. A/C Condenser mounted
  4. Heater core modified/lines routed
The Following was my first post
Hi. Not new to the forum, but lurked for a while. Was originally in the market for a Supra but the wife liked the FRS better ***I know***. Anyways, I bought the FRS back in April 2013 and slowly learned as much as I could before purchasing anything. Haven't told many people, but, I decided to do a 2JZ swap.
There's a LOT left in this build, hell the FA20 is still in the car, but it's moving faster now. I purchased my 2JZ/V160 setup almost a month ago and I've been tearing it down to put goodies on it.
First brought it home
First time washed
Detailed and OptiCoat by Garry Dean
Another shot (blacked out headlight housings were done a few days before)
Side shot after detail/OC
Ok, it's a new car, not much to look at, but I wanted to preserve the paint as best as I could. Moving along...
Picked up some KW v3's, Raceseng CasCam plates, Raceseng shock tops, B2 20mm(f)/25mm(r) spacers and SPL LCA's, no pics of LCA's/spacers, but they're pretty billet.
Friend Ross at Trust Automotive installed my suspension. Props!
Also bought some interior pieces. All black from the EU GT86 spec, as well as Raceseng slammer knob and reverse lockout.
I think that does it for looks for now. Suspension handles very well, but not extremely noticeable compared to stock. Stock works great in this car!
So, then I bought my 2JZ/V160. Buddy Ryan from Mike Balf racing helped source and even helped me pick up the motor! Four hour drive!
At this point, I was taking the manifolds off just to clean the head better. I took off the exhaust manifold to see the valves:
I wanted to just clean/replace the seals, but ultimately I decided to do some more.
Who knows what else will change in this setup, but it's happening and all I can do is move forward now! Thanks!
Last edited by slicktop; 04-20-2016 at 01:21 PM. Reason: Updated Last Post 07 Apr 16
slicktop is offline   Reply With Quote
Old 06-10-2014, 11:53 PM   #2
suaveflooder
Couple of these are starting! LOVE it!
suaveflooder is offline   Reply With Quote
Old 06-10-2014, 11:54 PM   #3
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Sexy. ID2000s are pretty beefy, I was using 1000's and still had room for play at 600WHP, what are your goals with this?
Build Thread
Instagram
Old 06-11-2014, 11:24 AM   #4
ModBargains
ModBargains's Avatar
Drives: FRS, M3
This is something I need to see
ModBargains is offline   Reply With Quote
Old 06-11-2014, 12:22 PM   #5
jdm-az-fuk
Drives: 2013 Fr-S
I hope someone actually finishes one of these. All the swapped 86s are shop cars. I really can't believe no one has made conversion parts yet. The market will be huge.
jdm-az-fuk is offline   Reply With Quote
Old 06-11-2014, 12:48 PM   #6
Biddys
Drives: AE86
frs 2jz
Portland speed industries can handle all your conversion needs.
tunedbypsi.com
Biddys is offline   Reply With Quote
Old 06-11-2014, 12:50 PM   #7
slicktop
Deep 9s. I chose the 6466 because I got a good deal on it and I'm holding out on the rear end for a little bit because of the cost. I'll be working on this in stages. First stage is getting it all in, second stage is build rear end, cage, bigger turbo, nitrous.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
Old 06-11-2014, 01:01 PM   #8
SLC_BRZ
Drives: 2013 WRB BRZ
This is going to be epic.
SLC_BRZ is offline   Reply With Quote
Old 06-11-2014, 01:07 PM   #9
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
more pics! more pics!!
Old 06-11-2014, 01:56 PM   #10
husker741
Sub'd
husker741 is offline   Reply With Quote
Old 06-11-2014, 02:08 PM   #11
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
subscribed for cool jz stuff
SomeoneWhoIsntMe is offline   Reply With Quote
Old 06-11-2014, 02:15 PM   #12
Maowc
EndlessClouds
Maowc's Avatar
Drives: 2013 Scion FRS
subd. looking forward to when you are done!
Take your dreams and smash it!
Maowc is offline   Reply With Quote
Old 06-14-2014, 09:48 AM   #13
slicktop
New plates came in
I suppose I have to finish it now...
Old 06-14-2014, 10:39 AM   #14
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
You've caught my attention.
AVodka14 is offline   Reply With Quote
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 09:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 08:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
