#169 |
Drives: Ultramarine FR-S
#170 |
Drives: Scion FR-S 10 Series 6MT
First of all thanks for the great tutorial. I was able successfully swap my led's on my cluster gauges, but when I put everything back together I noticed that my needles don't do the sweeping motion when turning on the car. Any one know how to correct that?
#171 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
You have to set the shift light again, only the brz does the sweeping, while the fr-s gauges shows u where u set the shift light on start up
#172 |
Drives: 2015 Subaru BRZ Series.Blue
Does anyone have advice/pictures on taking apart the start button? Two of my friends and I are working on redoing the entire interior of my car and none of us could figure out how to get to the LED in the start button without breaking the assembly. We've all searched the forums and googled to no avail. Any help is appreciated!
#173 |
I would think that it's made to not come apart for theft protection.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#174 |
Drives: 2015 BRZ
Door "window and lock" LED's
does anyone by chance know the type of LED that is used in the door? I was able to get everything changed over to blue but the LED's in the door are different from what is used on the console.
I did try the larger LED's but they did not work (left one original LED installed to verify if I soldered backwards. |
#175 | |
A Demon
Drives: Raven GT86
If this is the one you're speaking of its a T10 wedge bulb. ![]() Sent from my iPhone using Tapatalk |
#176 | |
Drives: 2015 BRZ
Are these correct? LED |
#177 |
Drives: 2015 BRZ
#178 | ||
#179 |
Drives: 2015 BRZ
I did take it apart but was too nervous when I saw it was wired like an electro magnet. I also could not figure out how to remove the white plastic slider without breaking any tabs. Sadly, it's still red.
#180 |
Drives: 2015 BRZ
3mm round tops? Or the piranha's?
#181 |
Drives: Toyota FT/MT 86
Guys does anyone know if the gauge cluster the entire assembly is replaceable. I'm asking this as I have a toyota 86 not GT , its same as scion frs.
I want to buy a spare gauge cluster just in case so I leave my original untouched. some people the gauge cluster it paired with the ECU of the car but I don't think so. What do you guys think or know about this. |
#182 | |
I Love custom Turbo kits
Drives: Limited BRZ
| Gauge Cluster on FRS | tonytduc | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 07-24-2017 10:56 PM |
| BRZ cluster gauge swap? | InYOHface | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 03-25-2017 07:31 PM |
| WTB gauge cluster | Basti | Want-To-Buy Requests | 3 | 04-09-2014 03:54 PM |
| Gauge cluster mod? | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-27-2013 11:59 PM |
| Want to try a gauge cluster experiment with me? | stockysnail | Northwest | 2 | 04-12-2013 11:57 AM |
