View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-25-2014, 10:23 PM   #183
loogs
Drives: on cruise control
ive have been torturing myself lately about this very subject. i recently decided that i would push off getting boost till next year. this thread has changed my mind. im going to enjoy my car the way it is, ill do more minor modding, and not take a chance. once im done having fun with this car, ill get an STI and be boosted from the factory. fuck that.
this post right here! wow! thats all i have to say about that
So I guess I decided to compile the list today:
@Frs300
  • Full Blown Turbo Kit
  • 93 Octane Full Blown Basemap
  • Blew the motor in less than 100 miles, due to the vacuum lines being placed incorrectly on the wastegate and overboosting
@nelsmar
  • Vortech Supercharger Kit
  • E85 FA20Club Dyno Tune
  • Blew the motor after 12,000 miles due to tune running too lean
@alexisfire02
  • Larger Sprintex Supercharger
  • FA20Club Dyno Tune
  • Blew the motor on the drive home from getting it tuned
@Innovate Motorsports
  • Innovate Motorsports Supercharger Kit
  • 91 Octane Visconti Tune
  • Blew a motor while attempting to develop the OTS tune to sell with the kit (kits now ship with Delicious Tuning Tune)
@Jesse@JDLAutodesign
  • JDL Turbo Kit
  • JDL Tune on AEM EMS only utilizing the port injectors
  • Blew the motor up do to melted wastegate line and an overboost
@civicdrivr
  • 93 Octane Visconti Tune
  • Blew up the motor while on the dyno
@shiro
  • Greddy Turbo Kit
  • Full Blown Tune
  • Blew the motor in less than 600 miles believe to be caused by the cam timing and prior damage to motor
@cf6mech
  • Accelerated Performance Turbo Kit
  • E85 AWDTuning, Texas Tune
  • Blew the motor when it crushed a rod bearing most likely due to the tuning
@Unleashed
  • Blew the motor because local mechanic installed a 15 PSI spring and ran a 7 PSI basemap and over boosted spinning a bearing
@Michaeljp92
  • P&L Turbo Kit
  • E85 JRTuned Tune
  • Blew the motor because the car was purposely pushed beyond the limits at the drag strip to find out what the actual limits are, the tune was fantastic, the power was just a bit up there for the factory rods to handle
@Cross
  • STS Rear Mount Prototype Turbo Kit with Custom Intercooler Setup
  • E85 Moto-East Tune
  • Blew the motor running 18 PSI possibly due to cam timing issues and the heads lifted
@C130NAV
  • Speed by Design (SBD) Turbo Kit
  • Unknown Tune
  • Blew the motor running between 12-15lbs of boost
@kingkai23
  • JDL Turbo Kit
  • E85 Prime Motoring/JRTuned Tune
  • Blew the motor while on the dyno because the plug on the TiAL wastegate port came out allowing the car to overboost and allowing a rod to exit the motor
If anyone knows of any others, please post them up.
loogs is offline   Reply With Quote
Old 07-26-2014, 09:17 AM   #184
xwd
If you don't like having to do a built motor, don't modify the STi...
Old 07-26-2014, 11:09 AM   #185
randomthoughts
Drives: 2014 White BRZ
I know this is off topic but has there been any blown stock engines on only Unichip or OFT tunes. I didn't find any threads in the search.
randomthoughts is offline   Reply With Quote
Old 07-26-2014, 01:21 PM   #186
DRACHENV6
Drives: tata nano
My impression is that the wastegates are critical components with no backup system in case of failure.. Why are people doing this?
There is a small margin for error. Ive never boosted, but I think that there should be some sort of checklist after installs/before dynoing or simpler components. A backup system or two would save alot of headache would it not?
DRACHENV6 is offline   Reply With Quote
Old 07-26-2014, 02:31 PM   #187
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Waste gates are pretty reliable pieces of hardware. I've never seen one fail. Never heard of it even...
You can always incorporate a boost cut into the tune in case of over boost, like the manufacturers do with turbo cars.
Sellout is offline   Reply With Quote
Old 07-26-2014, 02:47 PM   #188
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Everyone of them has a reason though? If installed correctly, tunes correctly and stay within limits there seems to be zero issue with those folks. See mileage thread and remove tinfoil hat.
Old 07-26-2014, 03:08 PM   #189
D K
Stig's dark passenger
@Unleashed
It seems weird that a bearing would spin when overboosting.
I myself am running a custom supercharger setup, have 9(?) track days so far and an excellent tune from Shawn Church @church Automotive Testing
So far, so good.
Had some other issues like melting my aluminum race mufflers, but the engine is going strong, making power and no logged knock events.
Car will hopefully be part of the SoFlo owners group by december or january
.....with my built engine
D K is offline   Reply With Quote
Old 07-26-2014, 03:38 PM   #190
Sellout
Mr. Cranky Pants
Sellout's Avatar
It's actually not uncommon.
Knock creates intense combustion chamber pressures, which dramatically increase the pressure on the rod bearings, the oil gets squeezed out and you have metal to metal contact, bearing spins.
Old 07-26-2014, 04:24 PM   #191
xwd
Yeah especially at the torque people are making with turbos. The SC kits aren't anywhere close. Everything gets stressed.
The WG issues are unfortunate.
Old 07-26-2014, 04:35 PM   #192
DRACHENV6
Drives: tata nano
Correct me if I'm wrong, but I would classify overboosting as a WG failure. A secondary/tertiary backup system would account for installation errors, etc.
Old 07-26-2014, 05:33 PM   #193
Sellout
Mr. Cranky Pants
Sellout's Avatar
Look through that list above and try to find an example of overboost caused by failure of the wastegate.
That doesn't really matter. Preventing knock is all in the tune. Even a bad N/A tune can rattle the motor with knock and spin the bearings(or worse).
I've seen built race engines with fully forged bottom ends come apart due to knock with less than 200 ft lbs at the flywheel.
Old 07-26-2014, 06:05 PM   #194
loogs
what are you saying? just curious
Old 07-26-2014, 06:13 PM   #195
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ejs blow up easily at less power.
Old 07-26-2014, 06:23 PM   #196
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
In the last 6 years our shop has built over 600 EJ's, and 99% were built because of failure. The other 1% were preventative. Ejs have what we like to call "glass pistons". From what we've seen already, the FA20 is a much stronger engine.
The Racers Line is offline   Reply With Quote
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 07:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 11:53 AM
