Old 09-08-2013, 12:34 AM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Highest HP on stock motor using only 93/94 octane?
I generally don't care for E85 as I can't get it. But I do have access to 94 octane which is readily available where I live.
I'm curious to know how far the stock internals on pumpgas 93/94 have been pushed with forced induction.
It's looks as though FullBlown holds the record on stock internals but they did it on E85. I wonder if ~400whp is possible on straight 93/94 (obviously with all supporting mods). Also, is there a record holder for most power stock internals on regular pumpgas?
Thanks.
hmong337 is offline   Reply With Quote
Old 09-08-2013, 01:59 AM   #2
sw20kosh
Drives: 2013 Black FR-S
The problem becomes knock threshold not engine internals.
On pump fuel you will run into a ceiling where you can increase the boost but you must decrease the ignition timing to compensate for knock. At this point there would be no benefit to running more boost.
This ceiling is different for every kit. A big turbo will produce the best peak whp as it doesn't have to run crazy high boost to do it. I have seen several Full Blown kits running 300-330 on pump. Looks like ptuning's GT3076r is running about the same on pump fuel (and more power with meth injection).
I will say that it is too simplified an approach to say "I want the highest HP kit". There are many other factors to consider like spool, daily driveability, mounting locations, turbo used and what application you want it for.
Old 09-08-2013, 02:09 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
So it's a pretty sure bet to say that the pumpgas limits on the stock motor is in the low 300whp range?
I'd just like to get an idea of what can be achieved without having to rip apart the motor to swap in some lower compression pistons.
Cool SN btw...
Old 09-08-2013, 02:14 AM   #4
Sonolin
Cool SN btw...
That's definitely what it seems like. I've seen some do 350 whp on pump, I believe ptuining as well as full blown. But I wouldn't go past ~300whp on pump personally, without lower compression. I bet its doable if you have a good tuner & reliable gas though.
EDIT: Honestly I think the sweet spot for the 86 is 280-320whp which should be doable on pump with most turbo kits. I've also seen a vortech get 300 on fa20club dyno with their header + smaller pulley.
Sonolin is offline   Reply With Quote
Old 09-08-2013, 05:14 AM   #5
nix
nix's Avatar
Drives: AVO BRZ
I agree 280-320 whp is a great power range.
@sw20kosh & @Sonolin comments are good.
It depends what you do with the car but I have a great tuner and on 98 ron we personally feel 300+ is pushing it.
nix is offline   Reply With Quote
Old 09-08-2013, 12:39 PM   #6
jamesm
I have 280ish now and I'm already needing more. Just get a turbo so you can up the boost a few times as it gets boring, extend the excitement as long as possible lol.
Old 09-08-2013, 03:01 PM   #7
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I've seen the P&L kit dyno at 320 on pump
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-08-2013, 04:07 PM   #8
dabocx
dabocx's Avatar
Drives: Scion FRS
300-320whp is the highest ive seen on pump. Ive seen higher on meth+93 if you want to go that route.
dabocx is offline   Reply With Quote
Old 09-08-2013, 05:15 PM   #9
lexusb3
Drives: FRS
i made 337 on pump
lexusb3 is offline   Reply With Quote
Old 09-08-2013, 05:15 PM   #10
lexusb3
Drives: FRS
it was fun untill i got bored and went e85 and then 16 lol
Old 09-08-2013, 05:16 PM   #11
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
On our kit, we've 300~320 on pump 92 (10% ethanol). With a pure 93/94, we could push it a bit further. But realistically, if you are planning to run pump gas, you'd give yourself a bit of margin to not only deal with possible gas issues in your area, but in case you go to areas that only have 92 or 91 octane.
AVOturboworld is offline   Reply With Quote
Old 09-09-2013, 11:53 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
330 to 340 whp is about the limit on 93 octane. Pretty much any turbo kit can hit over 300 whp on 93 octane.
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
highest mpg possible steve87j Scion FR-S / Toyota 86 GT86 General Forum 29 12-28-2012 09:06 PM
