#2647 | |
Drives: FRS!!!
Would be interested in that video. |
#2648 | |
Stealth
Drives: Ultramarine FR-S
#2649 | |
Of course, if you *want* noise, you can always add a BOV... |
#2650 |
Drives: Neptune GR86
I'll make a better video soon, but mine is noticeable.
Still not sure if there's something wrong with it though since it doesn't seem to sound like anyone else's.
#2651 | |
Old Fart
#2652 |
Drives:
The kit has a bypass valve that acts like a blow off valve but it recirculates. I am not 100% sure but I believe you have to recirculate it so that Mass Air Flow does not go crazy. I think if you vent it to atmosphere the engine could keep shutting off, but I am not a tuner so I don't know if this is the case or if there is a work around.
#2653 | |
#2654 |
Old Fart
Seems like pretty ridiculous work just to make the car go woosh woosh.
#2655 |
Drives:
You would have to do the same thing with a turbo kit.
#2656 |
Drives: Crystal Black BRZ(Sophia)
#2657 | |
Couldn't we use the Perrin BOV?
![]() Quote:
I'm still setting things up for a custom tune anyway, so if that sounds doable, maybe I can try it since it fits with my build.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2658 | |
#2659 |
Drives: Subaru BRZ
[ame="http://www.amazon.com/Turbosmart-TS-0203-1022-Kompact-Universal-Valve/dp/B001N21VIE/ref=sr_1_1?ie=UTF8&qid=1437514985&sr=8-1&keywords=turbosmart+dual+port+25mm"]Amazon.com: Turbosmart TS-0203-1022 Kompact 25 mm Dual Port Universal Fit Blow Off Valve: Automotive[/ame]
this "fits" perfectly as a replacement of the plastic one we get with the kit. you have to set it pretty soft but it works. whats cool too is that you can just use one of the included plugs and it can be full recirculating instead of 50/50 Vent to atmosphere/recirculate. it'd just be a replacement to a higher quality piece... not really needed but hey... because racecar. I had it 50/50 when running the carb tune and I can tell you it didn't run as smooth as when running the included plastic BPV but it still ran. I swapped back and forth between the turbosmart kompact and the included plastic BPV. ever since switching to a speed density tune its a lot smoother, but still not as smooth as the carb + plastic BPV, probably like 95% there though so I don't mind. when you build up boost and let off the throttle it has that initial high pitch BOV noise, followed by a "who just unplugged an air compressor hose?" noise.
2014 WRB BRZ
#2660 |
Drives: 2013 Scion FR-s
Hey guys, not sure if my google-fu sucks or what. Thought I'd try here to find some answers. For those who have supercharged their car and have installed a wideband AFR gauge with stock headers, where are you guys mounting your O2 sensor at. I've seen a thread where they have welded the O2 bung on their front pipe right before the cat, or on their overpipe, but instructions and other people say to place the sensor before any cat. Does that mean you can't have any cats in front of the sensor including the primary to have an accurate reading. Or does it mean you just have to have it in front of a cat? So would I be good welding the O2 bung to either the overpipe or the front pipe? Any help would be appreciated.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
