Old 03-20-2016, 06:20 PM   #15
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Did this today and it seems to have resolved the sound issue, exhaust smell under the hood, and CEL's so my initial problem is gone.
Which got rid of my other codes, but now I have:
Old 03-20-2016, 07:02 PM   #16
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Damaged heated O2 sensor and/or plug.
Old 03-20-2016, 07:17 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
HLHachiRoku: it's about different rates of thermal expansion of header & engine on heating up and cooling back that flex joints were meant to deal with, not about how tight mounted header feels on cold engine. But true, most recent headers for FA20 don't have flexjoints anymore, so i guess even that thermal expansion wise it deemed not necessary after rich experience for few years of platform being around, and was eliminated for manufacturing simplicity/costs and mechanical strength reasons ..
Old 03-20-2016, 11:53 PM   #18
steve99
as @Wayno said damaged 02 sensor or wiring or o2 sensor not conected or blown EFI HTR fuse see http://www.ft86club.com/forums/showthread.php?p=2206548
Old 03-21-2016, 01:06 PM   #19
B-R-Z
B-R-Z's Avatar
And this is the one with the gray connector that connects first in line going from motor to overpipe?
Old 03-21-2016, 05:13 PM   #20
steve99
yep theirs a grey and black connectors, make sure grey to grey and black to black as the front/rear 02 sensors are different.
The one with shorter cable goes to front o2 longer one to rear cannot remember colours off hand.
Old 03-21-2016, 05:17 PM   #21
B-R-Z
B-R-Z's Avatar
But I'm trying to determine which one may have the issue, is it possible to determine that based off of cel code?
Old 03-21-2016, 05:29 PM   #22
steve99
from cel code its sensor 1 which should be front 02 sensor
Old 03-21-2016, 07:49 PM   #23
B-R-Z
B-R-Z's Avatar
Do you happen to know what I can do to troubleshoot? I checked the fuse but it looks ok
Old 03-21-2016, 08:31 PM   #24
steve99
brz wiring diagram
http://www.google.com.au/url?sa=t&rc...wTIabWl0Jc6WWw
page 105 and 106 wideband 02 is front o2 sensor
both have heaters
looks like green/whit is earth (b+) and heater is HA1A and HT1B
un plug sensors and measure resistance of heater, if its open circuit then its likely the o2 is stuffed.
don't measure or probe connectors with o2 plugged in as its directly back to ECU and you might stuff the ECU.
check with ignition OFF and connectors unplugged probe the 02 sensor not back towards ECU.
Old 03-22-2016, 10:26 AM   #25
B-R-Z
B-R-Z's Avatar
Thanks steve. To test this, I need to check the resistance between the +/- leads of the heater? I'm still not sure which wires to test, the diagram doesn't make much sense to me.
If it does turn out bad, am I ok buting a Bosch sensor or should I go oem? Any pointers are appreciated
Old 03-22-2016, 11:07 PM   #26
steve99
best run the oem one unless the bosh is a direct replacement with exact same charasterisics as oem sensor.
test for resistance between ground and the HA1A and HT1B conection on each sensor the wiring is colour coded
alse take it to a shop for them to test
Old 03-22-2016, 11:38 PM   #27
B-R-Z
B-R-Z's Avatar
It says bank 1 sensor 1 doesn't that narrow it down to the sensor before the cat
Old 03-22-2016, 11:50 PM   #28
steve99
yes thats the one its indicating
but sensors are expensive, so it best to confirm it no good
Keep throwing P0463 codes on low gas l0aded Issues | Warranty | Recalls / TSB 44 08-19-2021 07:02 PM
P1170 P117B Direct Injection Issue? gonzo Issues | Warranty | Recalls / TSB 4 01-11-2017 03:23 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 03:50 PM
P0171 and P1171 codes help! dejxx Issues | Warranty | Recalls / TSB 3 03-24-2015 12:36 PM
Crawford BPB CEL P0171 AZ_Racer_1 Issues | Warranty | Recalls / TSB 16 02-06-2015 07:37 PM
