Old 02-11-2015, 10:21 PM   #1
gonzo
Drives: frs
P1170 P117B Direct Injection Issue?
EDIT: Thread title is wrong. I believe the codes were 0171 too lean and 117B direct injection. NOT 1170 port injection.
I have had oft headers and e85 for almost a year now. Today car threw check engine codes P1170 P117B. I reset the codes, and I did a wot pull from 3k to 4.5k and the afr was good, mid 12s, and LT trim was around 7%, but then adv mult dropped to 0.0. Ignition adv is in the 40s. I recorded it and will post the log soon.
I'm going to make another log on the way home. Which parameters should I be logging? Should I try another wot pull? Any ideas? The car sounds and idles fine.
Thanks a lot for any help.
Cross posted to Software board.
gonzo is offline   Reply With Quote
Old 09-26-2016, 09:30 PM   #2
Zenkicoyote
Drives: 2015 supercharged frs
did anyone ever find a fix for this?
Zenkicoyote is offline   Reply With Quote
Old 09-26-2016, 09:34 PM   #3
http://www.ft86club.com/forums/showthread.php?t=82274
Old 01-11-2017, 02:27 PM   #4
rikixass
rikixass's Avatar
P1171/P117B: After speaking to my mechanic, he mentioned that i'ts a intermittent failure of the high pressure fuel pump. I bought some Lucas injector cleaner, just to be on the safe side. I guess it's just a waiting game until it fails. that is, if it's even that. It could be leaks in the intake, or exhaust too. Will keep y'all posted, but it hasn't returned since I disconnected the + from the batt and let it sit for a half hour.
rikixass is offline   Reply With Quote
Old 01-11-2017, 03:23 PM   #5
rikixass
rikixass's Avatar
Pump is roughly 600.00 from dealer.
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 07:17 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 03:50 PM
direct injection cc size bulldog11267mad Forced Induction 5 12-03-2013 02:24 AM
Stock Direct Injection PSI Fenrir Engine, Exhaust, Transmission 18 05-17-2013 04:03 PM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 03:05 PM
