Old 01-26-2019, 12:49 PM   #15
johnmayqwerty
Drives: 2016 Scion FR-S
OK, here is plan B.
Find a place that is warm to park your car for 24 hours.
Maybe it will thaw out and clear itself.
That used to work, when I lived back in the Midwest, to thaw out frozen fuel lines.
humfrz
Don't have one. I'd try a space heater, but it's 1 degree here. So I have to wait.
johnmayqwerty is offline   Reply With Quote
Old 01-26-2019, 04:51 PM   #16
humfrz
OK, plan B - expanded on. What I mean by a warm place is any heated garage (like the local muffler shop, quick lub, auto shop, tire shop,). Make a deal with the manager/owner to park your car there overnight for a fee.
Plan C. If you have a garage/barn, but it's not heated, park your car, carefully place your space heater underneath (near) the car, place an old electric over the car and plug it in. Let it cook for 24 hours.
Plan D. Bubba's plan. Place a old fashioned 100+ watt light bulb under the rear end of the car, cover the car with blankets (Bubba didn't have an electric blanket) and simmer for 25 hours.
Plan E. Just place a piece of black electrical tape over the dash light and deal with it come spring thaw.
humfrz
Old 01-28-2019, 10:59 AM   #17
johnmayqwerty
E
Old 01-29-2019, 04:38 PM   #18
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
With OFT, you can load up a tune you've customized to disable the CEL. Or, keep the gas level between 3\4 and 1\4 and the car won't run the EVAP system test. PITA but it's a work around.
Or just say screw it and delete the EVAP system and disable the CEL. But then you might run into state inspection issues.
Old 04-01-2019, 02:43 PM   #19
johnmayqwerty
Quick update: The weather is better now, and the MIL DID in fact turn off on it's own, and it's stayed off for some time now. I did have to unhook the evap vent hose inside the wheel arch and hold it near the ground to let the water drain out. But ever since... it's all good. I've put a sort of custom-designed vented plug on it (3d-printed) to stop further water or snow intrusion, we'll see how well that works.
canister, differential, evap
EVAP Line??? gtpvette Engine Swaps 12 09-18-2023 12:24 AM
Potential Evap System issues after over filling tank? BirdTRD Issues | Warranty | Recalls / TSB 5 09-17-2018 09:10 PM
EVAP/CPC Solenoid Delete? BRX Issues | Warranty | Recalls / TSB 7 09-09-2017 08:52 PM
Evap readiness Brz_Joe Forced Induction 0 06-02-2017 02:09 PM
EVAP Solenoid Ryan P Forced Induction 0 06-25-2014 09:43 AM
